Thread: To block or not
    To block or not
    I am going to be putting up a 27' round once I have my site level and the install plan shows to use a 2"x8"x16" block below each bottom plate on the 18 wall uprights of the pool. In talking with others that have had their pool professionally installed as recently as last week, their installer didn't use them because as the block tips on the ground so will the wall upright.
    Have you had a block issue on your pool? How many years with the block in place?
    If you didn't use block have you had issues?
    Should I block it or not? I already have the block so it is not a money thing.
    27' Round Esther Williams 52" wall
    Sta-Rite sand filter T-200BP1
    Sta-Rite pump MDL 1G02L 1.5HP
    Casey's Avatar
    SW PA
    10,444
    Re: To block or not
    I would block it. We used blocks on my previous above ground that my dad put up and I used the same blocks with this above ground that I put up.
    My blocks do not and have not tipped once. If they would tip, it's because it wasn't properly leveled in my opinion i.e. dead space and compaction over time.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: To block or not
    from what I've read it's a matter of preference...but I would follow what's in your pool warranty/instruction manual so you don;t mess up the warranty. There really isn;t that much downward force on round pool uprights...the pressure is more outward than downward..the downward pressure is under your liner
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: To block or not
    BAH!
    Of course you 'block' it Anyone who had the blocks shift didn't compact or properly prepare the ground first
    I love easy questions
    Luv& Luk
    -Ted
    Re: To block or not
    So do I set the block on top of the level ground or sink them flush?
    Top
    get the ground level
    set the blocks on my track line
    put my sand down
    compact it
    then put up the track on the track line and blocks
    or
    Flush
    dig out the block spots and set them flush with the ground
    put up the track
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: To block or not
    flush...dump the sand in the center of your pool...then the sand gets spread out and compacted after wall is up...this will prevent sand blowout
