Thread: Finally Finished
    Finally Finished
    Yey...I am finally finished installing my Above Ground pool. I have to say, other than
    My brother passing away (that was horrible)
    Bad ground prep contractor
    Bad Sand (see previous comment)
    Not knowing anything (yeah, this should be top of the list)
    Learning I know NOTHING about leveling sand bottoms
    It is beautiful. Right now it is balancing out, and other than Minnesota dropping about 20 degrees, and the bottom of the pool feels more like a minefield (not going to worry about it this year, most likely will drain it next year early and fix, technically it is a multilevel pool ) -- It is good.
    Thank you very much for all of your help
    PS- Really, I know NOTHING about level sand. It is sad...and I complained the ground wasnt level to begin with...g'z...
    Also, I now know what masons sand is, and why I should have used year gorilla bottom
    Bel Air 24' Above Ground Round Pool
    Hayward- GM152 Sand Filter
    Hayward- SP711-13 Multi-Port Valve
    Hayward- SP1511 Pump 3/4HP
    Hayward- SP1092 Skimmer
    Hayward- SP1411 Return
    Polaris 65 Cleaner
    gonefishin's Avatar
    Joliet, Il.
    Hi cowrack,
    I'm glad to hear that your enjoying your pool...please do take time to relax. It sounds like you could use a couple of nice easy relaxing days.
    I'm sorry to hear about your brother passing
    God bless,
    21' Aqua-Leader AGP (10,200 gallons).
    Hayward cartridge filter and two speed pump.
    Aqua-Cal HeatWave 100k (HeatPump)
    Salt 3200ppm (in non-salt water pool)
    Borates 20ppm (slowly raising)
    Aqua-Rite SWG
    Congratulations on getting the pool complete.
    I too, am sorry to hear of your DB's passing. Sending prayers to your family.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
