Results 1 to 8 of 8
Thread: Is tonight the night I stop shocking?
    Southgate, Michigan
    6
    Hello,
    I had opened up my pool to a green swamp, and have diligently following the instructions here. I have kept my shock level up to 25, as per the pool calculator, based on my 10,000 gallon pool and CYA of 60, it has worked so far just like everyone said it would.
    This morning my FC level did not drop, it was still 25 , and I could see the bottom of my pool , but it doesn't sparkle. I think that it could look better, and I realize it's very close. This is my question, do I keep it up to shock level one more night to have sparkle in the morning? Or do I just let the filter finish the job? Any advice is appreciated, ty.
    10,000 gallon AG pool, Hayward 1HP sand filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Is tonight the night I stop shocking?
    I realize you're asking a specific question, but the info here would be very helpful: pool-school/read_before_you_post
    are you using a fas-dpd test to do the overnight loss test? if so, you are done shocking, the junk just needs to be filtered out.
    Southgate, Michigan
    6
    Ty, ty....I have adjusted my signature. Yes I bought the TF-100 kit, and so the testing was a fas-dpd. I've owned a pool for over 20 years, and was so happy to have found this site to finally teach me how to manage it, instead of fighting cloudiness and algae. By the way my kids and bf thought I was crazy to put bleach in it, and fought me every step of the way, wanting to take me to the pool store buy what they thought I would need. Now 6 days later I can see the bottom for the first time in a long time...Love you all and all the help you give.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    that's great. tell them that pool stores in many parts of the country sell and recommend liquid chlorine which is about twice as strong as bleach. what are your current test results?
    Southgate, Michigan
    6
    These are today's results as of 3:30 pm
    FC 18
    CC 0
    TC 18
    PH 7.8
    TA 120
    CH 200
    CYA 50
    Temp 80
    I'm guessing that the CYA went down a little from backwashing, vacuuming to waste, with a slight 3 inch refill. I'm also going to wait on the ph until the chlorine is in a normal level.
    I'm off to the outside , the sun is out and its going to hit 80 today.....a rare thing this summer....ty again
    30,421
    JD,
    I have enjoyed reading your thread. You have really gotten the concept of BBB very quickly and done a great job on your pool......very nice work.
    I'd do just as you are doing. If, in a couple of days, your water doesn't sparkle, I would suggest bringing it to shock level again for about 24 hours. I have done that with mine a couple of times this summer and I see an improvement when I do. I can't give a precise explanantion other than there was some residual organics in the pool but it does seem to work for me.
    Yours will likely sparkle with just a little more filtration. Nice to be in charge of your pool, isn't it?
    Southgate, Michigan
    6
    Its great to be in charge of my pool.......so much better to have a numbers to work with along with exact amounts to add from the pool calculator, and chlorine/cya chart. I used to use the oto and add enough chlorine to make it dark orange....lol. Maybe thats why my pool turned green and stayed cloudy. Ty to everyone who answers all the questions, most of mine had an answer already addressed in the forum.
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
