Results 1 to 7 of 7
Thread: Solar Powered Pump for Algae Plagued Wedding Cake Steps?
    I have been reading about the many algae problems with wedding cake steps. I can only assume the algae problem is either caused by stagnate water under the stairs, or the chlorine never makes it behind the stairs (again we're back to the stagnate water issue). While I may change my mind at some point...I really want to use these steps rather than a ladder type arrangement. I have had some rambling thoughts and would like some input regarding this issue.
    I was thinking about installing a 1000-1500 GPH bilge pump (about 4 amps), 12 volt powered by a deep cycle marine battery. It would be suspended about midway under the stairs, closer to the steps with a discharge hose points in the direction of the usual pool flow. A small solar panel would be used to keep the battery charged and a timer to allow it to run a couple of hours each night. I would think that since the water is being exchanged (2000 to 3000 gallons in a two hour cycle), it would greatly reduce the potential for the water to sit stagnate under the steps. If this works it would be virtually maintenance free and no additional electrical costs.
    Travis
    Travis & Kathy
    16x32 AGP (extra return outlet installed), Pentair Dynamo Pump (1.5HP, 60+ GPM), Sta-Rite Crystal Flow Sand Filter (300 lb), Clear Diamond Solar Blanket & Reel, Pool-Skim
    Aqua Trol SWG (also controlling the pump), TF Test Kit. (Everything self installed, up and running on 08/02/09)
    Enjoying the TFP site and appreciating the infinite knowledge of it's members... and I'm slowly learning how to maintain our new pool the BBB way!
    Four Winds Spa (love the tub...hate the filtration system). Best water quality in four years using the BBB method
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Re: Solar Powered Pump for Algae Plagued Wedding Cake Steps?
    I have the steps and haven't had any problems. I used them with other pool too. I vacuum inside them every so often, keep my chlorine levels up, and when I add water I put the hose behind them.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    oh and I took the hand rail off of them a long time ago. So I don't have to remove them when I cover for winter.
    Travis,
    I was just saying in another thread that it will be a rich person that invents this! I try to keep my chemistry in check, but still have problems with the stinking steps!
    After you get done designing such a neat pump, get started on designing some new cake steps with an expanded "beach" for little ones that like to STAY on the steps. I'll order one of both, thanks!
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    4A at 12.65V is a hair over 50W. Running the pump for two hours will require charging from the panels to be about 50W for 4 hours or 25W for 8 hours due to inefficiency in the charging process. A small panel won't do it. You will be over $300 for the panels another $100 for a charge controller, $75 for a cheap battery plus the cost of the pump that won't last very long at that kind of duty cycle.
    geoshecks's Avatar
    May 2009
    Perry Hall Maryland North of Baltimore
    77
    I have wedding cake steps and had always had problems w/ algae. esp. since I used to use Baquacil. I Took advice from some on TFP and drilled three 1 1/2 inch holes on the vertical surface of each step. I also drilled some new larger holes on the sides. The water flow has been greatly improved and I have had NO algae under the steps. Another side benefit has been that the steps do not want to "walk" the way they used to. They stay in place much better since the water flows through better. I used a keyhole saw to drill the holes. There has been no effect on structural integrity.
    I'm at work so I can't post a pick, but if you do a search you'll find some other examples.
    Geoshecks
    Perry Hall, Maryland
    27' round above ground, 17100 gal, vinyl, Hayward1.5hp, 200lb.sand, EX baqua-goo user.
    Thanks for all the input. All in all… I guess cutting additional strategically placed holes in the steps would be the simplest thing to do. I continue to learn from this group!
    Travis & Kathy
