Thread: Isolating solar heater?
    Vero Beach, FL
    462
    I'm getting ready to buy all the plumbing I need to hook up my solar panels to my pool plumbing. The builder is installing a 3 way valve and a check valve just before the 3 way. I'll be adding an additional check valve on the return line from the solar panels. I've seen some schematics that show a ball valve in the straight pipes going to and coming from the solar panels to isolate the panels. Why is this necessary? If I have a check valve and the 3 way valve, I can bypass the solar panels, so I don't see the purpose of the ball valves.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Isolating solar heater?
    I don't think that they are really needed and my system doesn't have them. The check valve and solar valve should provide enough isolation. They are more useful for systems which do not have a check valve on the return or no solar valve. Some installers put them in so they don't have to rely on the check/solar valve to be a 100% seal in case of a failure.
    Mark
    Mantua, NJ
    80
    Some of the 3-ways are positive seal, no leakage past the closed part, and some have a hole in the gate part to allow the panels to drain without opening the valve. So in theory, if you have to cut your solar pipes after the 3-way and leave them open for repair, a small stream of water may escape from the valve.
    Not really sure how much water would go out the hole, since it would travel the least resistence. Of course, if the solar input was the straight path and not the 90 degree turn, I would expect a heavy stream of water escaping.
    If you have room for the ball valves I would just install them. Maybe $40 for both?
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    The two 2 way valves are for isolating the panels in the winter time AFTER you have drained all the water out of them. So you can't inadvertently put any water in them i.e. turn the soar on. water in panels can freeze and crack them.
    Factory Warranty Station for:
    Vero Beach, FL
    462
    Thanks for the replies. Although I'm in south Florida, there are a few times a decade we do get below freezing, so making sure it can't accidently get water by a leaky 3 way valve is a good reason to have ball valves.
    I was not concerned about saving money as much as reducing restrictions as much as possible. I was reading in another post about ball valves causing high restrictions when open.
    Solar heat
    22,553
    While true for most standard ball valves, you can buy full port ball valves. The easy way to tell is to open it and look through it. If the hole is the same size as the ID of the pipe it connects to then there won't be any restriction.
