Results 1 to 13 of 13
Thread: Test Strips
    Jul 2009
    New Jersey
    29
    Test Strips
    Do the Aquacheck test strips work and are they OK for daily testing???? Total noob here!
    22.000 Inground Vinyl-2 years old
    Hayward EC75 DE Filter
    1 1/2 Superpump
    CL200 Chlorinator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Test Strips
    They aren't the best way to go. What chemistry are you wanting to test?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Test Strips
    Quote Originally Posted by TRazzNJ
    Not in my opinion....
    pool-school/pool_test_kit_comparison
    They are very inaccurate and difficult to interpret. Back in the day when I used strips, my CYA read at 30-50 when in reality it was well over 100. I don't trust them.
    Jul 2009
    New Jersey
    29
    Re: Test Strips
    Quote Originally Posted by JohnT
    I need to accurately test for free chlorine, Cyanuric acid and PH. Why can't I find the TF100 kit for sale on the internet??
    1 1/2 Superpump
    CL200 Chlorinator
    Mar 2009
    Huntsville, AL
    156
    Re: Test Strips
    Try this link! http://www.tftestkits.net/
    Hope that helps,
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Jul 2009
    New Jersey
    29
    Re: Test Strips
    Thanks , Just found it...I was searching Taylor and TF100.........Doh
    1 1/2 Superpump
    CL200 Chlorinator
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Test Strips
    Add your pool specifics to your signature. It helps people in answering any questions you may have. Another person from the (uh-Humm ) great garden state.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    Re: Test Strips
    I made the mistake of buying these test strips last night. At first glance, they seemed to be just what I wanted. When I saw that there was one test for bromine AND chlorine, I started to get suspicious that I wasted my money. When I read the insert, which stated that bromine is not suited for outdoor pool use, and that the ideal bromine levels are around 3 ppm, never going above 10... well, that pretty much put the nail in their coffin.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Test Strips
    the oto drop test is for chlorine and bromine too. they're tested the same way.
    Re: Test Strips
    The problem with test strips is not that they can read bromine, but that the ranges they offer are often to wide to be truly useful. The CYA test, for example on my old strips can be either 0, (called "Low"), 30-50 (called "Ideal"), 100 (called "OK" even though that should be called "Drain 1/3 to 1/2 of your pool water"), 150 or 300 (both called "High" where it ought to be called "Drain and refill until you get down to 50 and stop using the pucks you idiot".
    The Free Chlorine level can be 0 (called "Very Low" should be called "Add chlorine right away"), 0.5 (called "Low" should be called "Add chlorine right away"), 1 (called "OK" should be called "Add chlorine right away"), 3 (called "Ideal" should be called "Ideal if CYA is 20"), 5 (called "High" should be called "Ideal if CYA is 40"), or 10 (no comment but is beyond what they called high and should be called "Ideal if CYA is 100")
    The other values are equally useful.
    All that said, I still will use them when I am too lazy to get out the TF100 test kit since my CYA is now in the ideal zone and therefore the minimum FC for me is 3 which is right in the middle of the range. When it gets to 3 I know exactly how much chlorine to add and I tend to overshoot.
    Guest
    Re: Test Strips
    Bromine and chlorine are tested exactly the same, only the scale is different. Bromine readings are aboue 2.25 as high as chlorine readings for a given color swatch on a test, be it strip, tablet, or liquid reagent and whether it is DPD or OTO (not sure about Syringaldazine)
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Test Strips
    yeah, I was totally wondering about syringaldazine myself.
    Guest
    Re: Test Strips
    Quote Originally Posted by reebok
    it is used in the FACTS method (free available chlorine testing with syringaldazine) and also in many test strips. If the strip changes to shades of purple for the chlorine test this is what it is using. If the chlorine test changes to shades of red it's DPD and if it changes to yellow through green it's a variation on OTO.
