Results 1 to 9 of 9
Thread: Added Muriatic acid and my pumps worked better?
    I am a newbie at pools just having bought a house with a pool. My pH was at 8.4 and I just added 1/2 gallon of 20 Baume muriatic acid to pool to lower pH. Strangely, my pump just perked up and is working much better. Any ideas? I thought perhaps my filter just got toasted and the resistance has decreased? or what? Any ideas? Curious to the answer? It is a filter cartridge as far as I know. Probably a dumb newbie question I know.
    25K Inground Plaster, Waterway pumps, Cartridge filters, Heat pump pool, Laars LX Spa Heater, Aqualogic, SWG
    22,553
    Re: Added Muriatic acid and my pumps worked better?
    A couple of things. First welcome to TFP.
    Second, tell us a bit more about your pool. You can fill in your signature by clicking the user control panel right under the big TFP logo on the top left of the page.
    How did you add the acid? Did you pour it in at the return or add it in the skimmer?
    Thanks. I added the acid into skimmer. Dropped pH from 8.4 to 7.3. A little drastic perhaps.
    Jan 2009
    Cupertino, CA
    1,966
    You possibly cleared up some corrosion or scaling in the pump. but don't do it again... in general liquid chemicals should be poured slowly in front of a return with the pump running so they dilute asap.
    --paulr
    BBB "Intermediate Swimmer"
    Thanks Paul, I just went back to the pool school link and reread that advice. Duh! my bad. You don't think I tweaked the cartridge filter? Thanks for the quick reply.
    Jan 2009
    Cupertino, CA
    1,966
    You'd have to open up the filter and look at the cartridge to know for sure. Muriatic is potent stuff, it's always possible you put holes in the cartridge.
    --paulr
    22,553
    You did just what I suspected. As Paul said, DON'T do it again. {Edit> Muratic Acid should not be added to the skimmer <end edit} Hopefully all you did was clear up some scale or corrosion. That would make the pump work better. I'd check the filter if I were you just to make sure there's not some damage.
    {edited to remove reference to chems allowed in skimmer} (thanks for the correction, Dave)
    30,431
    CYA is the only thing that should be added to the skimmer.
    Just to head off another "urban legend" from developing, many on this forum add everything to the skimmer except muriatic acid.
    That has been my procedure for five years, recommended by Ben Powell from the old PF and, assuming you aren't a dummy and glop everything in at once, it will work just fine.
    Others take a more cautious approach and I respect that but it's not the only way to do it.
    Jul 2007
    Rockville, CA
    99
    Did you happen to notice your filter pressure prior to adding the muriatic acid? A comparison of pre- and post MA addition might tell you something about any negative effects on your filter. In any event, you probably need to clean your filter anyway, just read and re-read the procedure in your manual carefully. If you didn't receive one with the house, check out the manufacturer's website where they are usually available.
    Also, you may want to try adding only a cup or two of MA at a time and see how it affects you pH readings. A half-gallon is a lot to add at one time. I believe I've read that a large, fast drop in pH will result in a fast rise. It's better to add small amounts more frequently.
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
