Results 1 to 9 of 9
Thread: Frame set pool and solar panel
    West Michigan
    108
    Each year we set up my frame set pool in our yard and mostly enjoy it. But it isn't very warm, perhaps because of the lack of direct sun? Would it be worth it to get a set of solar panels to add some heat? Has anyone added these to a frame or easy set pool? How did you do it? We have a solar cover that we use during the night to keep the heat in that is there. DH is willing to give it a try if I really want to get some off ebay. I think I wouldn't need many for my 18' by 48" deep round pool.
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    gonefishin's Avatar
    Joliet, Il.
    413
    Re: Frame set pool and solar panel
    Quote Originally Posted by kimrst
    How close/far is the nearest area that gets good sunlight from your pool?
    Where are you located?
    What temperature does your pool warm up to? and how much higher would you want to get your temp?
    take care,
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    West Michigan
    108
    We live in SW Michigan, Once we got up to 85. I don''t think, it was that warm often, but on a hot sunny day, after a long day at work, a cool pool with a floaty and a beverage is awesome, even if it has to be a frame pool. Part of the pool ends up in the shade, but the garage roof has sun all day. So I'm thinking that a 2x20 solar panel off ebay might just do the trick? The garage and the pool are about 12 feet apart. Thanks for the help.. Kimrst
    Mar 2007
    Knippa, Texas
    289
    The usual recommendation is that the solar array be around half the surface area of your pool, in which case you'd need three or four of those 2x20 panels.
    (9**2 x 3.14) = 254 sq ft (approx) is the surface area of your pool; each 2x20 panel is 40 sq ft.
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Even one panel would give you warmer water. You would probably have pump issues, especially if you try to put the panel on the roof. Most AG pools have the panel on a rack or on the ground near the pool.
    Get a cheap one on eBay and give it a shot.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    How big is that pool? We had one panel on a 18' Easy set years ago and it made a very big difference. The trick is making sure the smaller pump that comes with those pools does not have to work too much to take care of the panel. Keep it close by and don't make it pump the water up to a roof. Keep your solar cover to keep the heat in you make with the panel - you will really enjoy it and it will be worth every penny.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2007
    Morris, IL
    477
    I doubt that the pump would push water up onto a roof. That is alot of head pressure, if I am not mistaken 1 vertical foot is equal to like 10 pounds of head pressure, and I cheap pump probably would not push it.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    West Michigan
    108
    Thanks everyone for the replys. I think its time to talk to the neigbors and get out the chain saw. Just trimming some of the trees that border us and our neighbors might make enough room to get the solar panels near the pool and neaten up the yard. We have a DS who is having a HS grad party June 9th so only the most important projects are happening right now. I want the pool up and running, the solar panels will have to wait till after the party, besides we need the yard for the picnic and the grilling. Thanks..Kimrst
    Mar 2007
    Morris, IL
    477
    Yes, cutting trees down is my favorite thing. If they are a nuisance, I say knock them. I have one tree right now, a perfect Scarlet Maple, I do like that one, and it stays.
    steve
