Proper Pool Water Levels
h2ctpdjl
0
251
Indiana
What is the "norm" for an IG pool's water level? Is it necessary to keep it at the water level "mark" on my skimmer, or is it ok to raise it a bit? Can too much water cause any type of problems with the pool equipment?
From what I hear, most keep their water level at about the middle of the skimmer.
I have had my water level higher, quite often 2/3 up, and have no problems.
They say that the 'skimmer' action is not as good at a higher level, but I have not noticed that being a problem.
Just my .02 :wink:
I am like you then. I keep my water level about 2/3 of the way up on the skimmer. Circulation does not appear to be impeded, as the recirculated water still bounces off the side wall across the pool and back again. Just wanted to make sure I wasn't causing any kind of "overload" on the equipment. As always, thanks for your input.
