Results 1 to 7 of 7
Thread: Suggestions for a water-base silicone spray?
    Sep 2007
    Toronto
    106
    My aquamatic motorized pool cover calls for using a water-based silicone spray for lubricating the sliders which run along the tracks, I am unable to find one that says it is water-based. the closest I could find is Jig-a-loo spray which says it is non oil-based. It seems to wash off quite easily from the fingers. Is this something I could use?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Suggestions for a water-base silicone spray?
    I'm sure it's a satisfactory lube for the cover, Call em and make sure it won't put your water in a funk.
    Jig-A-Loo USA Inc.
    211 S. Center Street, Suite 205A
    Statesville, NC 28677
    704-871-0308
    Toll-free : 1-877-554-1555
    Factory Warranty Station for:
    ya know what WD 40 is a Water based lube use that.I would never use this junk on any metal surface though it will just rust your junk up. On chains i use a chain wax or silicon spray like liquid wrench.
    Guest
    Quote Originally Posted by Vistal
    WD40 is NOT water based. The WD stands for 'water displacment' and it was the 40th formula developed. It is a petroleum based lube. It also does not contain silicone.
    http://www.wd40.com/faqs/
    LIQUID WRENCH also is petroleum based and does not contain silicone but they do make one that contains Teflon.
    http://www.gunk.com/lubricants.asp
    While your intentions were good your info was faulty.
    Aug 2009
    29
    ya WD-40 should never touch anything rubber / plastic / fiberglass in a pool. (Though it has a place in the tool box for sweaky filter tank nuts)
    I LOVE silicone spay, I personally use a food grade silicone made by RDS. It lubricates very well. But it must be used with experience; since like all silicone sprays they will expand rubber. This is a nice tool but can be a curse if not used correctly. ... like spray your o-rings seconds before you assemble. ... if not.. they just may not fit by the time you get to it.
    Once you use this stuff, you will never use a silicone "lube" like magic lube again.
    Guest
    Here is a water based silicone spray:
    http://buyfitnessonline.com/osc/product ... cts_id=703
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by tgramm
    Will it hold seal plate o-rings (Sta-Rite) in place during assembly?
