Thread: green pool building deck
    Hi
    Thanks for allowing me to join your group
    My question......pool the other day crystal clear....trying to build a deck around pool with pressure treated wood. Is it possible that some saw dust could have got in pool as the pool started turning green on the floor, didn't know it chems in wood had an effect. If so and anywho I need to clear it up ....What can I do ?
    Thanks andrew.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: green pool building deck
    Doubtful.
    Can you please post a full set of test results (and how they were obtained? Pool store, strips)
    30,415
    98% chance you don't have adequate chlorine in your pool. I doubt the pt wood had anything to do with it.
    If you could post a set of test results, we could help you with a better opinion. The above is simply a guess.....(but it's based on a common issue)
    Almost forgot....Welcome to the forum!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    With all of the chemical changes they have done to PT wood over the past few years I doubt its chemical related. I think also the saw dust would float on the surface and be skimmed of by the skimmer. You would need to have a LOT of saw dust for it to affect the pool that way IMO.
    I think Duraleigh is right you dont have enough FC in the water and in order for us to tell could you post a full set of numbers please .
    Welcome to the forum BTW!
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
