Thread: AGP Install??
    AGP Install??
    We have decision to make soon ...
    We have a deck on the back of the house that is basically **** and needs to be torn down and either rebuilt or a patio put down.
    We have a basic Intex 18 x 48 metal frame pool (not blow up).
    I was thinking why spend the money on the deck and leave the pool in the middle of the yard?
    How about a nice big patio and place the pool on it. It would be on a nice level surface, closer to the house and would get A LOT more usage and I would get my yard back. Also when the time came to move away we could easily take the pool out and leave a nice patio which would allow the house to sell better (homes with pools in this area don't exactly fly off the market).
    I have searched but it appears everyone puts these on ground is it wrong to put it on a patio?
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: AGP Install??
    You can put it on the patio. You might decide to put foam-type insulation under it for a bit of cushion....
    Re: AGP Install??
    Quote Originally Posted by frustratedpoolmom
    Thanks anything in particular (or particular thickness) I should use?
    ~ 18,000 Gallons
    Compupool CPSC24
    KleanKiddiePool's Avatar
    Oct 2009
    San Antonio, TX
    10
    Re: AGP Install??
    We buy the foam sheets and cover them with plastic. I think the foam is about 3/8" thick. It's the type that's designed to go between walls. (Not attics) It's very affordable.
    Linda
    12' X 36" Intex Metal Frame Set (2530 GAL)
    2500 gph Intex cartridge pump
    Aquabot Pool Rover Jr.
    Tons of trees and pollen
