Thread: Timer Question
    Timer Question
    I have a Hayward 6003T that I just fired up in a new pool. I also have a Hayward 1hp Superpump and an Aquarite SWG that share and circuit through a timer. I have read the schematics and literature, but just want to make sure I am doing this right. The timer will shut off power to the pump and SWG and when the heat pump senses no water flow it will shut off, basically into a standby mode. I tested and get a PS error code, which the manual says is normal for TCO. The 6003T does not have a TCO feature, so the timer will be the "boss" in this installation. I just want to make sure I am not missing something here. It makes me a little nervous leaving power to the heat pump with no water flow. This is an expensive piece of equipment and I DON'T want to blow it......
    If somebody could give me some reassuring words, I think I will sleep better tonight when I use the timer or the first time.....
    Greg
    3500 Gallon Pool/ Hayward HP6003T Heat Pump/ Hayward S244T Sand Filter / Aquarite Chlorine Generator / 1 HP Hayward SuperPump / We built this small pool ourselves and keep it around 90+ degrees.... Just right for the Pacific NorthWet
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Timer Question
    Bump...
    Hopefully someone with more knowledge will advise shortly - My heater had a warning that the heater should shut off a full 20 minutes before the pump, to allow it to cool properly. IDK if that makes a difference....?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Timer Question
    Greg, we just started installing heatpumps last year, so take this with a grain of salt
    Heatpumps are significantly different from gas heaters in that they 'suck' the heat out of the ambient air. As such, even if it tried to keep running with the pump off, they wouldn't be able to get hot enough to damage anything - the flow switch should cut it off when the pump stopped, but even if it didn't, the thermostat would kick in long before any damage was done to the system
    While gas heaters need (usually) a cool down period before the water stops flowing through them (a fireman's switch) heat pumps don't get hot enough to require one
    I believe you're all set to go
    Luv& Luk
    -Ted
    11,969
    Re: Timer Question
    Thank you for that clarification Ted!
    (I've never laid eyes on a heat pump)
    Mar 2007
    4,160
    Re: Timer Question
    Ann, you should know d*mned well that we all try to give the best advice we can
    It's part of what makes this THE BEST pool site available on the web We are always there to provide consistent and good advice for the questers, if one responder misses something or is slightly off- there's someone with actual or practical knowledge to set things right
    Hoorah! for TFP!
    Luv& Luk
    -Ted
    Re: Timer Question
    Boy, I feel a good night's sleep coming on..... Ted, thank you for the logical definition of the real function of a heat pump. It's still a bit of a stretch for a "logical" mind to grasp. It makes perfect sense the way you described it.
    FrustratedPoolMom (I love your name ) , thanks for the bump and contribution. As I am stepping into this pool ownership thing, I am realizing that the more I know, the more I need to learn. I really appreciate the contribution from this forum.
    Thanks to all... ,
    Greg
