Thread: Pressure
    Pressure
    Hey everyone...
    I just had a company install a solar panel system on my roof and is hooked into my auqalink.
    What i have noticed is when the solar kicks on the pressure jumps about 10lbs on the guage. Is this normal?
    The pressure is normally around 18lbs and goes up close to 30.
    14' X 28' igp Free form pool and 6'spa with spill over.
    Aqualink
    2hp Whisperflo pump
    Aqua Rite SWG
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Pressure
    With the increased head (more plumbing the water has to go through), and the trip up to the roof, Yes, you will have increased pressure, and this is normal.
    Factory Warranty Station for:
    Re: Pressure
    Do you think the 30lbs is to high?
    Aqualink
    2hp Whisperflo pump
    Aqua Rite SWG
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Pressure
    Quote Originally Posted by fmrock
    5 to 10 pound increase is normal. perhaps a bit higher if it is an exceptionally long run to the panels.
