Results 1 to 10 of 10
Thread: Simply amazing
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Simply amazing
    I've had this pool for 12 years and it has never gone this long without having some kind of problem. I got the chemistry in balance about the first week in April and it has been crystal clear and problem free ever since. I credit the guidance on this site and the TF100 test kit. Only wish I had found both years ago. I actually enjoy the pool now whereas before I wanted fill the $%&!! thing in and plant a garden.
    One thing that really amazes me is how constant the chlorine demand is - I really don't need to test chlorine but about once a week (but I do test every day - and sometimes twice a day) all that is required is to add 3 quarts of 6% chlorine every day. At 5 PM the FC will be 2.5 ppm adding 3 quarts brings the concentration to 4.0 PPM and it will be 3.5 - 4.0 PPM at 8 AM the next day. Then by 5 PM the level will be 2.5 again. It's been that way for two months and does not vary unless it rains all day. The other thing that is different is the filter backwash frequency. I use to backwash about every week or 10 days when the pressure drop would rise about 5 psi. The last time I back washed was either the last week in April or the first week in May - can't remember for sure - but the pressure drop across the filter is only 1 psi above the clean pressure drop after all this time - amazing.
    On the recommendation of my local pool store I use to shock the pool with tri-chlor once a week. I would add about 10 lbs at a time. The result would nearly always be a pile of brown debris in front of each filter return nozzle. I assume the brown gunk was dead algae that was too small to be filtered out. Then when I ran the polaris cleaner the brown gunk would be suspended and the water would be murky for several days until it settled to the bottom again. It was a very frustrating cycle and the pool was almost never completely clear. Now all that has changed and when the polaris runs the pool stays clear - amazing.
    So THANK YOU TPF for giving me a swimming pool that is a joy to use.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Simply amazing
    What a great post. Thanks for sharing.
    Of course, it's kinda worthless without pictorial evidence, LOL
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Simply amazing
    Yep, great post! BBB rocks!
    You knew you'd be busted on the pic, right?
    You're done SLAMing when:
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Simply amazing
    unfortunately I can't get a picture right now it's raining so hard I can't see the other end of the pool and the only before picture I have is this one - mine is in the middle .
    [attachment=0:2vubi53a]8371.jpg[/attachment:2vubi53a]
    11,969
    Re: Simply amazing
    Such a small house. You have no elbow room at all, eh?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Simply amazing
    yeah and a 20x40 pool. pfff. I hope you don't have to host a pool party with more than 75 people any time soon.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Simply amazing
    Very nice place you have.
    We'll let you by with that pic for now, but when it stops raining.......
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Simply amazing
    Here's why we have a pool. This is the six to eight year old Sunday school class and their Moms. The shots were taken yesterday between thunder storms.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Simply amazing
    Great pics. Looks like those kids are having a blast Nice house and pool.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Simply amazing
    Love it!
    Someone said, "the only unhappy pool is one that is not used."
    so, your pool looks very happy
