Results 1 to 7 of 7
Thread: Jandy Aquapure 1400 issue
    League City TX
    10
    The controller for my pool periodically gives a general fault of no flow and says to check pump. I can see that the water is circulating in the pool and overflowing the spa. My controller will display the pool water temp and the salt content just no give a flow signal. Is there an issue with the flow sensor for the Aquapure or is it possibly dirty? Thanks in advance for any help.
    12000 gal IG plaster, SWCG, cartridge filter, Spillover Spa
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Jandy Aquapure 1400 issue
    Hi
    I found this thread by doing a Google search (bottom Left corner) for your issue.
    http://www.troublefreepool.com/jandy...elp-t7409.html
    Can you post a full set of test results? That might give us some clues.
    League City TX
    10
    I took the flow sensor out and cleaned, made sure there was no build up in the cell. I also turned the power off to the unit and disconnected the sensor wiring and reconnected. When I turned the system back on I still get the general fault of no flow, check filter pump. Test results this morning were: FC 0.4, CC 0, pH 7.5, TA 70, CYA 60 and CH of 350. I know the stabilizer is a little low, but has been at this level before with no problem. Is there any way that I can test the flow switch or jumper around it so that I am not just changing parts? Thanks in advance for the help.
    Forgot to mention, I added a jug of bleach to get the FC up to 4.5 and a bag of salt to see if the salinity meter would register an increase in the amount of salt. The salinity went up the expected 350ppm. The temperature reading is also correct when checked against another thermometer.
    11,969
    Well its good to keep up on the chlorine until you get this figured out. The CYA level is not so low it should be causing this problem. I wish I had more knowledge where this is concerned to offer advice, hopefully someone who knows whats what will be along shortly.
    Jul 2007
    Suwanee, GA
    528
    Take a look at the 3rd post in this thread, there is a link the a 1400 troubleshooting manual.
    jandy-aquapure-apure1400-t13197.html
    If the link to the guide is dead, I have a copy I can send you.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Replace your flow/salinity sensor. I have been replacing a lot of these buggers lately. I think Jandy is having a problem with these but they won't admit to it .
    Factory Warranty Station for:
    League City TX
    10
    Thanks for the info, just what I was looking for. I'm waiting to get off nightshift so I can check it out.
