Thread: Do I need to shock after drain and refill?
    Mar 2008
    Roseville,Ca
    30
    I am helping a buddy.His CYA was over 300 from years of tablet usage.We drained and filles his pool last night.My question is do I need to shock the water to start.Here are the current number of a 8000 gallon pebble tec pool.Also in what order to I bring everything up in?Thank You in Advance oh Great Pool Website
    FC .5
    CC 0
    Ph 7.3
    TA 20
    CH 20
    CYA 0
    I will be using liquid cya just an fyi
    10,500 gal Gunite,Imperial White River Rok,1.5hp Pentair Whisperflo,320sqft Clean & Clear,Intellichlor 40 SWG,EasyTouch w/Remote,Pentair Pool Shark Sweep(suction side),Jandy AE2000 Heat Pump & 8mil Solar Blanket,SAM Light,18in Caribean Shelf,6 & 4 ft Benches
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Do I need to shock after drain and refill?
    not counting cya, TA, CH and FC all need to be increased soon. see here for recommendations:
    pool-school/recommended_levels
    pool-school/recommended_pool_chemicals
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    No, you don't need to shock.
    You don't need liquid CYA either, why the added expense? I'd just go with granular.
    Adjust the TA with Baking Soda up to 70, ASAP, so the PH level is stable.
    I agree, pick up some Calcium Increaser.
