Thread: A sudden drop in FC: Cause and effect
    Oct 2007
    Valrico, FL
    537
    Thursday evening I tested my pool for chlorine and pH. Normally I see a variation of a few tenths of a ppm change from day to day. However on Thursday I had a drop of almost 1 ppm! This worried me and go me to thinking about why the drop. I then realized that the day before I filled to pool. I fill with tap water, and in my area, tap water usually runs around 3 to 4 ppm of CC.
    So it looks like the CC in the fill water dropped my FC by 1 ppm. I am going to have to remember in the future to add 1 ppm FC when filling the pool.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Re: A sudden drop in FC: Cause and effect
    I've read that more and more public water systems are switchingover to Chloramine to treat tap water. Chloramine is chlorine combined with ammonia.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, the 3-4 ppm CC would consume around 1.5 to 2.0 ppm FC (perhaps a little more) as chlorine oxidizes the monochloramine in the tap water.
