Results 1 to 10 of 10
Thread: Opinions on Cleaner please
    WestSidePool's Avatar
    Cincinnati, OH
    424
    I found a kreepy krauly for sale in my area that is about 1-3 years old.
    They are selling it for 100 (but i would like to talk them down)
    The one thing wrong with it is the part that goes into the skimmer is cracked, but they said it's still functional and they have used it up till now.
    I've been doing a lot of reading on Suction and Pressure cleaners, but still unsure of what to go with.
    I dont get alot of leaves or big debris in my pool unless there is heavy wind, most of it i can clean with the hand vac, just looking for an easier less maintenance way of doing it.
    Since this is the first I've owned a pool and have not experienced any type of auto cleaner, do you think i would be satisfied with the Kreepy, or should I look at a pressure unit?
    Thanks for the input
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    30,432
    Re: Opinions on Cleaner please
    Your pool is about the right size for a suction side but I wouldn't put a suction side in anything larger.....your's is at the top limit, IMO.
    Used cleaners with a lot of parts that wear out, are a cr*pshoot. It may be perfect, it may never perform well for you.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    405
    Quote Originally Posted by WestSidePool
    If your at all technically able then fixing a used cleaner shouldn't be a big deal. The part your talking about is about as easy at it gets.
    Pressure cleaners will get you a couple things. First, they won't tie-up your skimmer basket (so you need a dedicated return line). Also you could put a pressure cleaner on a timer and run it for an hour or as needed every day.
    That a pretty good deal for $100, you just have to decide if that cleaner is good enough and not regret it if it requires maintenance.
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    Cincinnati, OH
    424
    Kevin
    yes i can fix things, and i did realize that would just be a matter of gluing or replacing that part.
    I just wasn't sure how good suctions were compared to Pressure cleaners.
    They each have their ups and downs, and i've never used either to compare the two.
    Just the Pressure are just a little more pricey.
    Eric
    Guest
    Good rule of thumb for pool cleaners...you get what you pay for.
    Arizona
    924
    So, why are they selling it?
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    i have used a kreepy crawler for 10 years with no problems.
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    Cincinnati, OH
    424
    Quote Originally Posted by Buggsw
    Not quite sure.
    They told me they got it when they bought the house.
    So i'm not sure if they are filling there pool in, or if they upgraded to something else.
    Eric
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Save your money up for a robot - either a new or a refurb. No pump required either on suction side or pressure side and they just do such a wonderful job. They can be run before you even open for the spring so you don't have to wait for the water level to be raised up to the skimmer, etc.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Cincinnati, OH
    424
    Actually i just bought me a new Kreepy.
    Right now Pentair has a 100 mail in rebate on them.
    I just won a brand new kreepy off ebay, and before i bought it I checked with Pentair and they said they honor the receipt and rebate from the ebay seller.
    So brand new kreepy for dirt cheap, thats all i can ask for right now without spending $$$ on one.
    Eric
