Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Intex pool help
    Intex pool help
    So we put up the pool for the season last week or so. Since than I have been trying to get the pool water clear. It is cloudy. I was just reading and I am thinking it may be because the CYA is at 0 when I test it. So I saw someone mention to someone else that has the same size pool (15 x 48) to put 8 oz dichor in everyday for five days. I am using the HTH balance. But can I do it more than once a day to speed up the process?
    Also I notice the chlorine level is not staying overnight can this be one of the reasons?
    So after five days if my CYA is up to normal levels should the pool water be clear or will I need to do something else? I have also been adding one pound of baking soda everyday for the last few days, should I stop that for now?
    Edited to add:
    I have the HTH test strips. Here are the results from what I just tested.
    TH 200
    FC 5
    PH 8.4
    TA I can't tell it does not match any of the colors, it is blue
    CYA 30 - 50
    I am in central Utah. No salt water thing. It is the 15 x 48 pool, I don't know what the gallons are.
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Re: Intex pool help
    I am also a newbie, so I don't feel comfortable answering your question, but someone with more smarts will be along soon. Help them help you by telling them as much of the following info as you can in a quick post:
    1. pool volume in gallons if you know it
    2. type of testing you are using (test strips, red pH and yellow chlorine drop test, FAS-DPD, etc)(how did you determine CYA to be zero)
    3. test results if you have them (chlorine and pH minimallly)
    4. if you are using a salt water generator
    5. what your climate/weather has been like
    You could add some of this stuff to your signature, which is helpful. They are great on this forum, and will walk you through clearing up the cloudy water!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jul 2009
    South Texas
    32
    Re: Intex pool help
    I am also new at this. I just finished clearing up a BAD algae problem in an intex pool. in this process I have learned that two things cause chlorine levels to drop in your pool. 1. is sunlight. CYA is needed to protect your clorine from the sun. 2. is organics such as algae in your water. Algae is microscopic so just because you are not seeing any does not mean its not there. With the drop in chlorine without the sun exposure you may need to consider that it is possible that since you have had trouble maintaining your chlorine algae is trying to get a foothold.
    If you can post your test numbers I know several people can help you out with your water balance.
    Beginer trying to save parent's neglected pool
    Pool Specs: 24ft by 52in round above ground vinal and metal fram 13,500 gallon
    New sand filtration system
    Jul 2009
    South Texas
    32
    Re: Intex pool help
    Quote Originally Posted by thehopes5
    Edited to add:
    TH 200
    FC 5
    PH 8.4
    CYA 30 - 50
    Baking soda raises PH and your' s looks high to me.
    Click on the Pool School and read Pool Chemistry that is were I have been looking.
    Jul 2009
    South Texas
    32
    Re: Intex pool help
    What type filter do you have? Sand, Cartridge, and DE are the main ones. With Intex it's probably cartridge unless you have bought a new one.
    Re: Intex pool help
    It is the cartridge filter. Oh someone told me to use baking soda to make the water clear.
    Jul 2009
    South Texas
    32
    Re: Intex pool help
    That's what I figured it's what we had for my mom's pool until it broke and we replaced it with a sand system. Be sure to check your filter cartridge they can fill up quickly.
    I'm not sure about the baking soda clearing up the water but with your Ph that high I would hold off on it until you get some help from someone here.
    Re: Intex pool help
    I have been spraying out the filter several times a day to try and keep it clean.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Intex pool help
    So we put up the pool for the season last week or so. Since than I have been trying to get the pool water clear. It is cloudy. I was just reading and I am thinking it may be because the CYA is at 0 when I test it. So I saw someone mention to someone else that has the same size pool (15 x 48) to put 8 oz dichor in everyday for five days. I am using the HTH balance. But can I do it more than once a day to speed up the process? No.
    Also I notice the chlorine level is not staying overnight can this be one of the reasons? Yes.
    Depends on a combination of factors.
    Yes, stop adding baking soda! We use Baking soda to raise TA.
    Edited to add:
    The strips are not recommended. You need a chlorine/pH drop test kit. They are inexpensive and can be found at WallyWorld, K-Mart, Lowes, etc.
    TH 200
    FC 5
    PH 8.4
    CYA 30 - 50
    If the test is correct, your pH is too high and should be lowered to between 7.2 and 7.8.
    I suggest you take a sample to the pool store for testing and post your numbers back here in this thread. Also, you could pick up your dropper chlorine/pH test kit there.
    What have you added to the pool since the fill last week?
    Here is a link to a thread about trying to "simplify BBB for small pools....." which is full of great information: simplifying-bbb-for-very-small-pools-e-g-intex-t14533-80.html
    I think you will enjoy the read.
    Welcome to the forum
    You're done SLAMing when:
    Re: Intex pool help
    I don't have a pool store near me so i can't do that. Since I put the pool up I have shocked it twice. I have put 3 lbs of baking soda, lots of clarifier, some bleach and than I just started putting in the balance stuff (the stuff that helps the cya).
    Re: Intex pool help
    Well I could kind of see the bottom of the pool today so something must be working. I hope over the next week or so I will be able to get things under control and have a nice clear pool. My chlorine level did not drop overnight like it has been so hopefully that is a good sign.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Intex pool help
    Baking soda does not shock your pool. It raises your PH and TA, which is why your pool is cloudy and your PH and TA are way, way, way too high. Definitely stop that now.
    You will actually need to add muriatic acid or dry acid to LOWER the ph down to 7.6 to 7.4 or so.
    Chlorine is what you need to shock and sanitize the pool.
    HELP
    Posts merged by moderator
    I had another post but did not get much response on it. I have been reading and went and bought a new tester. I only have wal-mart near me so I got the HTH 6 way drop test. I was using the strips. A little bit of info. We have the Intex 15' x 4' above ground pool. We use the cartridge filters.
    I have been having issues with cloudy water. It has gotten a TINY bit better, like I can barely see the bottom of the pool where as before I could not. For the last 4 days I have been adding 8 oz of the HTH balancer (cynauric acid) and 2 cups of bleach.
    Anyways here are my numbers, hopefully you can help me get my pool clear.
    CYA 60
    PH 7.5
    Chlorine was orange so I could not figure out a number for it. I am assuming at this point it might be too high.
    TA turned green but when I added the titrant after 11 drops it still did not turn to red.
    TH turned to red but when I added the titrant after 11 drops it still did not turn to blue.
    Oh we are in central Utah.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Re: HELP
    The TA is probably higher than that, keep adding drops till it turns pinkish/red.
    Your CYA level is 60 which means your shock level is 24. You should stop adding CYA and consider replacing some water to lower the CYA level so that you need to use less bleach. We recommend 30-50 for CYA. I would drain down about 1/4 of the way and replace with fresh water. Recirculate for several hours and retest the level. Once you get the CYA down, find your CYA level on the CHART and that is where you get the recommend FC levels.
    To figure out how high your chlorine is, take 3 parts distilled (or chlorine-free) water to 1 part pool water. Test this solution, and then multiply the result by 4. This will test your chlorine up to 20, but you do lose some accuracy.
    I can tell you for certain that you don't have enough chlorine in the pool for your CYA level. 2 cups of bleach isn't nearly enough to reach shock level for a CYA of 60.
    So do the dilution method for testing, and do a partial drain/refill to get the CYA down.
    http://www.PerfectlyClearPoolService.com
    Mod Squad JohnT's Avatar
    SW Indiana
    9,127
    Re: HELP
    You need to stop with the CYA. You already have plenty in the pool, and the level may still go higher since it can take a long time to dissolve. Adding the CYA may be part of your cloudiness problem, since it's hard to dissolve.
    Make sure you are running the filter 24/7 unless you are swimming. AT 60ppm CYA, your recommended chlorine level will always be above the testing range for the test kit you have at 7ppm.
    It might help to brush the pool several times a day, and refrain from using any powdered chemicals. as well. Change the cartridge as required to maintain flow.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Intex pool help
    If your pool is 15 feet in diameter and 48 inches deep the volume is 5,280 gallons or 110 gallons per inch of depth.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Re: Intex pool help
    My CYA is now down to 50, but I reread the post and I did not let it circulate for a couple hours, myabe an hour. So the CYA might be down even more by that time.
    So than what do I do to get some clear water?
    11,965
    Re: Intex pool help
    After you get the CYA down to about 40, you shock the pool with bleach. Use the Pool Calculator to determine how much bleach you need to raise the FC up to shock level. Keep shocking, by testing and adding bleach as often as every hour if you want, until the water is clear and the FC is holding at shock level. Once the water is clear and the FC is holding at shock level, the algae is dead and you can let the FC drop to the normal level for your CYA. If you let the FC drop too soon, before the algae is dead, it will just come right back.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Intex pool help
    Quote Originally Posted by stev32k
    If it's the frame pool, that's correct; if it's the Easy Set with inflatable ring at the top, the Intex website quotes about 3700 gallons.
    --paulr
    BBB "Intermediate Swimmer"
  20. Back To Top    #20
    Re: Intex pool help
    After I get the pool clear and everything taken care of what are my steps to maintain it?
    And to the previous poster it is a metal frame pool.
