I just finished building a very small pool (8x18) and installed an AquaRite SWG. I have a Hayward 6003T heat pump, Hayward 1hp Superpump and a Hayward sand filter. Everything seems to be working fine. PH and Alkalinity are within specs. The free chlorine level is a little low, but I am slowly raising it. Salt level is at 3000 PPM. I have not tested or done anything with the cyanuric acid level yet as I don't have a good tester. I am a total newbie at pool ownership, so most of this is still a bit of a mystery to me.
My question is, periodically.... or more like frequently the water inlets will send out a major cloud of microscopic little bubbles that cloud the water. It will last for 10-30 minutes and then clear up crystal clear. My assumption is that the SWG is causing this. Is this normal? Is this cloud filling the pool because it is so small? Could this be something else in my system?
Any thoughts would be greatly appreciated.
Greg
Greg
