Thread: Solar blankets
    Solar blankets
    What is the longest you can leave your solar blanket on before it effects the water?
    My pool company that I purchased the solar blanket from told me to leave it on for no more than two days max at a time.
    Is this correct?
    63,000 litre IG Vinyl Pool. 16 x 32 Gemini. Zeobrite filled sand filter. Zodiac Duo Clear 130 Salt System, Hayward Pool Heater.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Re: Solar blanketsA
    A lot of people leave their blankets on when they go on vacations with no problems. I think if the water is balanced with plenty of chlorine its fine.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Solar blankets
    eventually you will have problems if the water is never allowed to "breathe". whether anyone has figured out how long that is, I'm not sure. certainly more than 2 days though.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Solar blankets
    The most I've done is 11 days, no problems whatsoever.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Solar blankets
    the last post here gets a little more specific on what happens, but no more time info than "extended periods".
    can-you-add-chemicals-with-solar-cover-on-t14013.html
