Results 1 to 8 of 8
Thread: cloudy water after shocking pool
    I have a new in ground pool. Just hooked up the filter with a small amount of brown algae present on the bottom of the pool. the water was crystal clear with filter and salt generator working. PH 7.6, calcium 250 alkalinity 150 free chlorine .99 and total chlorine 1.07. The pool is 36,000 gallons. I added 4 pounds of shock disolved in water. When I poured the disolved chlorine in to the pool it instantly produced white clouds in the pool and my clear water is now milky. I ran the filter for a day with little to no change. The algae looks to be resolving but I don't know what I did wrong and how I need to fix it. HELP Please.
    Keith
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: cloudy water after shocking pool
    cal-hypo will cloud if that's what you used. Also the calcium gets harder to dissolve when the pH is high.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    it was cal hypo. will it clear up on its own or do I need to add something else?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    pool-school/
    read pool chemistry, how to defeat algae, and how to shock. you need to be shocking with bleach or liquid chlorine.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    it should clear up on it's own, just don't let your ph get too high.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hi Keith,
    Welcome to TFP. To protect your investment, I'd suggest you invest in your own test kit:
    http://www.troublefreepool.com/pool-...kit_comparison
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by X-PertPool
    the calcium may, but I believe his numbers indicate a need to shock.
    30,424
    Cal Hypo certainly appears to have been the clouding issue and will likely go away on it's own.
    Your reported FC is far too low and it doesn't appear you have added any more since the Cal Hypo. The need to keep adequate chlorine in your pool is mandatory and your posts indicate you are overlooking that.
    Can you post a set of current test results including CYA?
