Thread: Neighbor's pool pump motor humming...
    May 2009
    Enterprise, AL
    54
    I'm babysitting his pool while they're on vacation.
    Pump will not start. When I tried, it gets hot and trips the circuit breaker. I opened it up and took out the strainer basket so I could reach in to turn the impeller. It turns by hand, but when I closed it back up and tried again, the motor still just hums.
    Suggestions?
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Neighbor's pool pump motor humming...
    If it's getting hot and tripping it sounds like the thermal overload, the fans that cool the motor could be blocked or broken, the motor could also be shot.
    if it's not overheating and just hums and trips it could be the capacitor, rusty contact switch, etc.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    pikeman's Avatar
    Jul 2008
    Pflugerville, Texas
    68
    Had the same problem. The pump would overheat, lock up and trip the breakers.
    It finally burned up. Sounds like that motor is shot.
    20K IG, WetEdge technology lined pool, TF100 Test Kit, CircuPool RJ60+, StaRite pump, Hayward DE filter, Hayward Navigator pool vac. Zodiac MX8 vacuum thrown in garbage.
