Thread: question about pool calculator and effects of adding chems
    If I put in the pool calculator that I have a 1000 gallon pool and have a "now" CYA of 20 and a "target" CYA of 40, I read the calculator to tell me to add 2.7 ounces by weight of dichlor.
    If I go down to the "effects of adding chemicals" field, if I enter 2.7 ounces of dichlor, it tells me it will raise CYA by 10. Seems like it should day it will raise CYA by 20. What am I doing wrong here?
    Thanks for any help.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Butterfly's Avatar
    South Carolina
    10,045
    Re: question about pool calculator and effects of adding chems
    Quote Originally Posted by crek31
    Actually, that is 2.7 ounces by weight of stabilizer (cyanuric acid) NOT dichlor.
    You're done SLAMing when:
    Got it. Thanks.
