Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: IF issue, where is the sensor wire located?
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Hi....I'm having the same 'IF' issue. Which/where is the sensor wire located? Does the ignitor just pop out? I want to test it like the above post suggests, but I'm not quite sure how to get it out. Does the burner assembly have to be removed to do this? Any help is greatly appreciated. PS.....sorry to hijack thread.
    New Pool: Pentair Intelliflo VS Pump, Pentair Quad 100 DE filter, Pentair EasyTouch control system, Pentair IC 40 SWG, Pentair Mastertemp 400,000 BTU gas heater, Pentair ScreenLogic wireless interface, Spa, Polaris QT Blower, Polaris 9450 pool cleaner, Gunite w/ Pebble Tec, 10K Gallons
    Old Pool: david-and-kristy-s-pool-build-t8676.html
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Hayward H400 Ignition Failure
    The flame sensor is usually pretty easy to remove. Just two screws holding it in place. You should see it mounted just above the burner. There'll be a single wire running to it, and it almost looks like a spark ignitor from a grill or something. Can't find a diagram right now, but reply if you still can't find it from this description and I'll track it down.
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    I was able to pull out ignitor and was able to see it spark. Is there any way to test the gas valve before replacing it? Thanks again for everyone's help.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    So it's sparking for a few seconds but the valve doesn't click and there's no half-second flame?
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Kinda.....I can tell it gets heat based on the fumes that come out of the top for a brief second. I have noticed that my pool pressure it higher than normal. I have two valves that I can use to bypass the heater all together. If the water doesn't pass through the heater, my pressure is about 18 psi, which is about normal. When running through the heater, it's about 28 psi. I backwashed yesterday and realized that it didn't make a difference. If there is some kind of blockage in the plumbing, would that keep it from firing up?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    It would cause the high limit circuit to open, which would kill the flame. You'll have to check continuity on your safety circuit just before you turn it on and then again once it kicks off. Got a volt meter/continuity tester handy?
    There's a wiring diagram on the inside panel that will show you the loop with the pressure switch, high limits, fusible link, etc. One of those components is probably opening. You just need to track down which one.
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    One step forward, two steps back! Bad luck just seems to follow me. I disconnected the PVC lines thinking that there might be some debris in the heater causing the psi to be higher. Couldn't find anything and the union nuts would not go back on. They were kinda out of round. Went to three pool stores and finally found a replacement set. Replumbed those and decided to "clean" out the heater. Took it apart the best I could. Made sure there were no spiders clogging things up. Removed lots of bark from the previous owner's landscape (heater is only two years old - he built a bigger pool and sold me his heater cheap - he's worth several millions, so he cut me a great deal). Anyway, there was a big dirt dobber's nest on the control board, so I removed as much of it I could without touching the board (insert possible problem here). Put heater back together and now, instead of getting an IF, I get no power/response from the heater. Clean heater, no power. I did the continuity test during the cleaning and it all seemed to work well. I guess I'm going to call a repair service unless someone tells me there a magical reset button that I missed that just needs pushing Just looking for the 'Easy Button'. Thanks for listening to my rant.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Did you accidentally disconnect a wire from the on/off switch?
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    The only thing that I disconnected from the board was a three prong set of wires that ran back to the temperature sensor. Most wires I just disconnected and reconnected them right back to test for secure connection. The blue/white wires on the water pressure switch may have gotten reversed (had to stop and come back), but based on the bend in the wires, I think I got it right. Even tried changing them with no luck. The blue is the closet to the front panel with the white behind it (if you can picture looking at the switch). That is all. I get no lights at all on the front panel. If a picture of everything would help, I'll be glad to post one (or a video). Thanks again for talking me through this stuff. Spishex, you are a great help to me and everyone else.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by GADawgFan
    The order of the wires through the pressure switch doesn't matter.
    If you're not getting any lights at all you need to check your incoming power, power from the transformer, fuses, and voltage selector settings (that shouldn't have changed but you never know).
    If you don't have your manual handy, here's a copy. You need the top of page 37.
    Before you go out and spend money on new parts, If you are getting "IF" the first thing to do is clean out your gas orifices, The metal gas tube will rust and flake inside and the orifice holes are larges enough for bugs and spiders to nest and clog the orifices, Removed them clean them out, Tap on the gas tube and get compressed air to blow stuff out (make sure gas and power to unit is off). You'll be suprised how much crud gets in there during the winter months. reassemble and fire it up, If this doesn;t work then start replacing parts. Igniter, Flame sensor and valve. Some have the expensive silicon nitride igniter which does not buzz, It gets red hot you can take it out plug it and turn on the unit (gas off) and it will glow red hot. (Make sure it doesn't touch anything)You know it works this way. And off to the next part.......
    40K gal rectangular IG Gunite ... white plaster ... 20 ft negative edge ... 2 Intelliflo VF 3050 pumps ... 2 Sta-Rite Cartridge filters ... IC60 SWG ... Pentair Thermaflo heat pump
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    I rechecked my connections and have power again. It made a big difference cleaning out the tube. Wow! Where is the flame sensor? Below is a video that shows the heater.
    http://s233.photobucket.com/albums/ee68 ... ideo28.flv
    Just to double check the wiring....are the blue and white on the right terminal?
    http://s233.photobucket.com/albums/ee68 ... ideo26.flv
    Thanks...David
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The flame sensor is at the end of the single white wire that goes down to the bottom right. It is part number 12 in the parts diagram in the manual I linked to above.
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Thanks for the manual. That one is much more detailed than the other one I was using. I will give the sensor a look-see tomorrow.
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Stupid Question of the day......on the pressure switch, when testing for continuity, I should be able to touch both terminals to tell correct? I went through all of the wiring/limiters/switches and it's the only one that does 'beep' (sorry for my ignorance) when testing. This should be my problem, correct? Or at least need replacing? Thanks...David
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Only one that doesn't beep? Is that with the pump on?
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    No...with power off. Do I need to try it again with the heater powered on?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The heater doesn't have to be on, but the pump does. The pressure switch is open when there's no water flow and closed when the system is under pressure.
    GADawgFan's Avatar
    Jul 2008
    Bremen, GA
    54
    Ah...understand. I will do that. Thanks again, David
  20. Back To Top    #20
    I am having the EXACT same problem with my EXACT same heater. Today I replaced a cracked pump housing which was causing a 3psi flow which I though was probably the issue... However, no such luck. Did you replace the flame sensor? Have you made any headway? Thanks
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star 1HP (1.85) pump, Hayward sand filter
    Nine Fafco Sunsaver 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
