Results 1 to 15 of 15
Thread: Need advice for repair after hail storm
    Shelley N's Avatar
    Denver, Colorado
    199
    We had a doozie of a storm the other night that included hail and tornadoes. I'm left with 3 leaks in two of my solar panels. I'm sure the fix is an easy one...I just don't know that it is. I've got to keep them on to warm the water after 4" of hail. Help!
    Shelley
    Denver, CO
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Need advice for repair after hail storm
    Shelley, I hope that this is the only damage from hail and tornadoes!
    Though I've never done it, there is a way to weld soft plastic like that to repair small leaks like the ones you pictured. My understanding is that you need the same type plastic and 'solder' it on.
    I read about it on PF. If no one else offers info on this, bump this thread tomorrow and I'll see if I can't link the info for you (I know the author -CarlD- and will use 'weld' as a first search term )
    Luv& Luk
    -Ted
    Dec 2007
    Central New York
    504
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Shelley N's Avatar
    Denver, Colorado
    199
    Thanks for the leg work Hotrod! My panels are approx. 9 x 4 so are a pretty unique size. They were imported from a company in Australia I believe that is no longer in business. My last resort will be to cut and plug as we all know we don't want to be doing that unless we HAVE to. I wonder if marine grade silicone will work? After all, it's just a little glue and a patch that can keep 11,000 gallons of water in a bag right? If it were drip irrigation, the storm would have plugged the hole, but it's not supposed to drip, so now it does. Geeze.
    I think the hail hit the ring around the hard plastic that inserts into the soft rubber and made a nick in it. Even though there are 2 rings on each fitting. I don't think there is any damage to the soft rubber.
    Waste - A tad more damage:
    Shelley
    Denver, CO
    Mar 2007
    4,160
    Shelly - sorry about the garden
    Here is the thread I was talking about on PF (I guess I don't have Alzheimers, since I remembered the post after 2 years )
    I certainly hope that you can stop the leaks soon!
    Luv& Luk
    -Ted
    If those tubes are plastic use a 2 part 5 min epoxy after the lines are drained . It will seal those holes up with NP. If they are metal use a resin core solder and some solder paste .use the solder paste over the hole and melt the solder on to the hole like a weld.Simple fix really.
    Shelley N's Avatar
    Denver, Colorado
    199
    Vistal - They feel like tire rubber...could they be plastic?
    Shelley
    Denver, CO
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    The epoxy fix does not work - we tried it on some Sun Grabbers we had some time back that suffered the same fate from hail. We had a few holes like that. The pressure from the water apparently was just too great. The panels were drained, blown out, allowed to dry for 2 weeks and glued. The expoxy did not hold and they soon leaked again. We ended up with new panels (which I like better anyways) I think the method from PF would be better.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Been a while since I posted here.
    I've struggled with welding panels myself. If the plastic is meltable, you can use a clean soldering iron to seal it. Find some place on the panel you can safely cut some plastic off of--there's usually SOME place you can find. Melt the panel and then melt the "solder" into it. Try not to make additional holes. Sadly, just a surface patch weld won't hold. At best it will slow the leak. You have to go deeper which is risky. But there's really no other way. There are plastic welding kits but the cheapest are about $125 to $150. The expensive ones run into the hundreds or thousands. Still, a clean soldering iron can do it.
    I have to make one correction: For metal soldering, you NEVER apply the heat to the solder--you heat the part and let it melt the solder. Also, if you are fixing ANYTHING using water that may contact living things (like people) you must use lead-free solder and plumber's flux...I just sweat-soldered in several new cut-off valves for some sinks in my house where the old ones had rotted out, so it's fresh in my mind. I've also done lots of electronics soldering so I'm aware of that kind of rosin-core lead-based soldering as well.
    But plastic soldering/welding is much harder. Good Luck!
    CarlD
    Stay ahead of your water!
    If you suspect you are going to replace the pannel i would try this. Try removing that tube and see if the Nipple its connected to is Broke OR if its just that tube.you may be able to Split that tube and add a new section of tube.
    Quote Originally Posted by Vistal
    Cutting should effect the heating process just reseal the cut >they make a black rubber type duct tape or use black duct tape.
    Shelley N's Avatar
    Denver, Colorado
    199
    Good news! Our insurance company says they will replace them! I can't believe it! Now where is that receipt from 4 years ago...?
    Now which ones do I replace with?! Any suggestions?
    Shelley
    Denver, CO
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    solar bear
    Shelley N's Avatar
    Denver, Colorado
    199
    Fafco seems to be the big dog in this arena. They have several different products to choose from. I think I get it that these are the ones designed for above-ground pools. Is the only difference a built in diverter? If that is the case I can avoid that as I have a diverter in my plumbing. I can't find that they make an 8x 4 or similar. Does anyone know?
    Shelley
    Denver, CO
