Thread: Alkalinity too high?
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    My alkalinity this morning was 130.
    Is that too high?
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Alkalinity too high?
    No. High Alk is only a problem if it causes the PH to drift up too high frequently, so that acid dosing becomes annoyingly frequent (usually more of a problem with a pool with water features or SWGs).
    If your pH is stable then don't worry about it.
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Ok. The PH did go up by .2 on me. Went from 7.5 to 7.7. I adjusted the PH back down. I'll wait and see if it drifts up again.
    11,969
    That's fine. What will happen is each time you add acid to lower the PH down, the TA will drop a little too. So eventually the TA will get into the recommended range and the PH should stabilize for you.
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Great! Thanks!
