Thread: Patched numerous holes today
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I did a leak detection today on a liner we installed in 2006 (about 10 holes or so), There were scrapes and punctures along the coves of the pool especially in the shallow end. Take this advise....
    wrap the ends of your pool brush in thick wads of duct tape; even though the edges are plastic they can get burs quickly if they touch the concrete. (see picture)
    Replace your brushes on your vacuum head when they are worn and inspect it to make sure there are no rough spots (rub your hands all over it).
    Also when you get a new liner installed or if you are installing the liner for someone else please make sure to keep the large piece of vinyl left over from cutting out the step area (if applicable). It is very useful for patching as it will match the pool exactly unless your liner is starting to fade.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Re: Patched numerous holes today
    I'm sorry to hear about your leaks - that stinks! What I did was use an xacto blade and shaved the entire plastic area until it was rounded and smooth all over. And I'm very careful about not banging the brush onto anything outside of the pool - as well as being very careful with it when I hang it back up.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
