Thread: need hayward pump parts
    fordman's Avatar
    Jul 2009
    Iowa
    119
    I am replacing a seal in my pump but broke the long mount bolts and can't find them. Pump is a SP1510-Z-1-XES and the part is the motor secureing bolt as in this picture.
    1988 Ceder Ridge
    24' Doughboy AGP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: need hayward pump parts
    Will a piece of all-thread rod go through the motor? I've had good luck using a piece of all-thread and two nuts and a lock washer on the end to replace a hard to find bolt.
    JohnnyT's Avatar
    Jul 2009
    Rochester, IN
    13
    Good morning fordman...You should be able to look for a Hayward pump dealer, in your area, on the internet but I have used the all-thread rod like JohnT described and it worked great. Just get a rod the same diamater as your bolt, use two nuts on one end (tightened towards each other in a jam-nut fashion) and either the same thing on the other end or a single nut and lock-washer. Mine was still holding several years later when I got a different pump. Good luck.
    12K, 21' Round AG, 52" Deep, Vinyl
    Hayward EC 30-DE filter - 1 hp Hayward Power Flow LX pump, 40 GPM
    Hayward AquaBug Pool Cleaner
    You must give some time to your fellow men. Even if it's a little thing, do something for others - something for which you get no pay but the privilege of doing it.
    Albert Schweitzer
    fordman's Avatar
    Jul 2009
    Iowa
    119
    would a motor shop have these or are the through motor style mainly used for pool applacations?
    1988 Ceder Ridge
    24' Doughboy AGP
