Thread: Bleach and CHlorine tabs?
    I just started BBB today to fix some problems can I use bleach and continue to put the Chlorine tabs in the canister by the pump?Thanks! Dean
    10,000 g , sandfltered, gunite pool
    with your CYA (probably still near 50 or 60 after your drain/refill) I would stop using the pucks right now. They are what caused you to have high CYA in the first place, thus rendering the amount of chlorine ineffective at keeping your pool clean.
    post some numbers here for better help!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
