Thread: So do I add CYA...
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    So do I add CYA...
    PH 7.8
    TA 80
    CYA 40
    TC 7.5
    The TC has dropped from 14+ in the last week but clearly the CYA is below recommended levels for a SWG vinyl
    Clint
    Pics of the build process
    34x16x25 Lagoon IG Vinyl 14,800gal (Oxford Tile/Glimmerglass 20mil)
    Pentair: Intelliflo VS3050 pump, Intellichlor IC40 SWG, Clean and Clear 320 cartridge filter, LA01N 3/4hp booster pump and Polaris 280 cleaner
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: So do I add CYA...
    Yes it is. I think you answered your own question.
    Also, tc is kind of a vague number. FC and cc would be much more descriptive.
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Sorry typo...it was a FC number not TC. (BTW those are last night numbers...CC was 0 two days ago)
    The reason I am hesitant to add the CYA is that the FC number is higher than it should be for a SWG Vinyl. I didn't want to add the CYA and hold the FC at the high level unless I needed to
    Clint
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It doesn't work that way, the FC will still drop if you aren't adding chlorine.
    You should raise the CYA to 70, leave the SWG off until the FC drops where you want it, and then turn it on adjusting the percentage till you find the right setting, to maintain your FC at the recommended range.
    awarsoca's Avatar
    May 2009
    Columbia, SC
    64
    Thanks!
    Clint
