Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Pool guys say I should be shocking with bleach as well???...
    Jan 2009
    NC
    49
    OK, when I opened the pool this season I decided to switch to BBB for normal upkeep. Working Great. But I still shock with the powder cause from what I thought bleach was only an upkeep and to shock you used every week or when needed. Pool guys say bleach is great, use it all the time, Is this true????? I travel quite alot so as much as I would love to care for my pool I cant, when I hired the pool guys this season they requested I buy bleach for them to use. I really didnt believe them which is when I found this site. But I guess so. So my question is can I use bleach to shock as well as upkeep???
    John
    15x30 inground vinyl pool. 1 hp hayward pump, 200 pound sand filter. 8 feet deep in the deepest part. 3 feet in the shallow. 4 returns 2 in the steps, 1 in the shallow end, and one in the deep, 1 skimmer (wish there were 2) and one Main drain. Only thing I wish is I had a more powerful pump, The jets never really put out alot of power. No frills pool. Has a light and thats about it as far as specail features go. BBB user ever since I opened this season thanks to TPF
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool guys say I should be shocking with bleach as well???...
    Yes, just bleach.
    Powders raise either Calcium level or CYA levels. Bleach doesn't have unwanted additives.
    Maintaining proper FC levels based on your current CYA levels means rarely, if ever, having to shock....
    Jan 2009
    NC
    49
    oh ok. I was told by my girlfriends dad to shock weekly. To just kill everything. So I guess I will just get more bleach for the pool guys, and say use it when needed. Hopefully If I get the new position at work I wont have to travel weekly and can take care of my own pool.
    John
    Quote Originally Posted by gman
    If you keep the chlorine at the right level and never let it fall to the wrong level, everything is always killed. You don't need to shock unless you've let things get out of hand.
    How often are these pool guys coming? I find that using bleach only, I have to add it to the pool every 3 or 4 days. That is with light usage and hot Texas sun.
    11,969
    That's pool store myth.
    If you maintain proper FC levels, the Free Chlorine is what "kills everything"....so there is no need to shock weekly.
    I've shocked my pool 5 times in over 2 years: 3 extended vacations and 2 winterizations. That's it....
    Refer to the CYA chart - never let the FC drop below your "min" level, and you should never have algae or need a reason for "routine" shocking.
    Jan 2009
    NC
    49
    Quote Originally Posted by anonapersona
    The pool guys come out once a week and just do the routine. Clean skimmers, vacuum, backwash etc. And they add bleach as needed. For 200 bucks a month their a life saver since my GF is not really as good as keeping the pool clean as she is using it. lol.
    John
    Mar 2009
    eastern washington state
    275
    wow man if i live closer i would do it for 200 bucks a month... really you should get GF to learn how to do it... its really easy even a blonde can do it.... I know i will get slack for that!!! but really let her try, she can do it
    good luck
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    11,969
    Hello: Blonde Hair Here.... :P
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by hayfarmer
    good luck
    haha, I was thinking the same thing. heck, I'd charge half that and still lose sleep over guilt.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    good luck
    Hayfarmer, please check your pm when you can. Up in the top left hand of the page should be a link that says "X new messages"
    Thanks.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by frustratedpoolmom
    WOW Ann, I'd have never guessed I guess I'll have to start typing slower (if that's possible)
    Luv& Luk
    -Ted
    11,969
    Quote Originally Posted by waste
    If you think that will help YOU keep up, by all means.
    Mar 2007
    4,160
    Keep up I've already lapped you twice
    Take care Ann, you know we all love you
    Luv& Luk
    -Ted
    Guest
    NOW I understand!
    11,969
    :P
    Mar 2009
    275
    sorry mom I did not know it was going to raise that much ruckus about Blondie's!!!!! Remember blonds are beautiful and we love ya
    Jim
    1 skimmer/2 returns
    11,969
    Tis all right, I can take it (I can dish it too, no worries.)
    Jan 2009
    NC
    49
    good luck
    haha, I thought 200 was quite cheap actually, before i had another company charging me 500 a month, that didnt last long. But im going to see if I can teach her anything about it when I get back from cali.
    But can somebody tell me what a phosphate is (sp). I got a call from them this morning saying the pool has phosphates and thats why I keep getting algae. What are they and whats the best way to get rid of them??? thanks a ton guys.
    John
    Have you tested the pool yourslef to see what the Free Chlorine level is, as well as the CYA level?
    I'll bet that you are getting algae because after 3 or 4 days your chlorine level is too low for the CYA level you have. A lot of BBB users add a little chlorine to the pool each evening. I wait and do a big jug on the 3rd day.
    I suspect that you will need to empty a jug of bleach into the pool mid week, or better yet, get the girlfriend to do that after she is done using it and while the filter is running.
    I will leave the phosphate discussion to the pros, but short answer, Doesn't matter -- you need more chlorine.
  20. Back To Top    #20
    Butterfly's Avatar
    South Carolina
    10,045
    Hey John,
    It would be most helpful if you would post a full set of test results
    If you google (bottom left) phosphates, you will get a ton of info. Phosphates are a non-issue in 99% of pools.
    You're done SLAMing when:
