Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Old Pool Owner switching from Pool Company to Self Maint
    Jul 2009
    Dallas, TX Suburbs
    8
    I have had a pool for a little over 3 years without a problem. Unfortunately, I have been paying a pool guy to come and maintain my pool. Lately, I have been seeing the mustard algae on my walls, which has prompted me to google search and I found this forum. I think I am about to fire my pool guy but I am very apprehensive about doing this as my schedule can be somewhat limited.
    I have a 15K gallon pool. I have a Jandy Onetouch automated system with a Pentair 320 Auto Chlorinator, Polaris 280 and a DE Filter.
    I am not afraid of the chemicals however, I do not have the time nor energy to go and get numerous gallons of bleach. I am thinking of using one form of tabs in the autochlorinator. Which brand/form of the tablets do you recommend. I will be adding the 20 mule team borax at 50ppm. I also need to know how much and type of shock to buy.
    My current levels are as follows;
    FA=2
    TAC=2
    PH=7.5
    TA=70
    CH=200
    CYA=50
    TDS=500
    Please help me as I take this plunge.
    14,500 Gallon Chlorine Pool made with Plaster. Pentair 320 Autochlorinator, Polaris 280 w/ pump, Jandy DE Filter, Jandy Onetouch Automated system.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Old Pool Owner switching from Pool Company to Self Maint
    I would suggest a SWG (Salt Water Chlorine Generator) as a viable solution...it may cost anywhere from $200-$1,200 upfront, but you will save that by not paying the PB anymore.
    22,551
    I second the SWG but keep in mind that you're still going to have to put time in testing and adjusting and adding chems as required. While it's about a 5 minute job per day it's still got to be done.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    One other tip you could use is this...http://www.waterwarehouse.com/
    If you send for their catalog, they have three inch tabs that are not stabilized...They come in public pool sized orders that can cost between $250 and $500...But they are chlorine tabs that are unstablizied which is what you want to use if you want to go that route. Personally, I don't spend more than 10 minutes a day on my pool. See Specs below...I buy 12.5% liquid Chlorine from my pool store...I am lucky enough to get it for $2.25 per gallon. I am on my secod two cases for the summer. about 60 ounces per everyother day keeps FC between 8 ppm and 3 ppm. This is all I need to maintain a happy and balanced pool. So that is all it takes. I maybe vaccuume twice per week. But if you have an auto cleaner that is even better.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Just a quick note on what Beave said (Hi Beave )
    YOU CAN NOT USE THE PUCKS HE'S TALKING ABOUT IN A TRI_CHLOR FEEDER!!!! ESPECIALLY IF YOU'VE HAD TRI_CHLOR TABS IN IT EVER!!! There is a very real risk of explosion !!
    If the finances are there, a SWCG is definitely the way to go If not, we'll help you work out something manageable
    Luv& Luk
    -Ted
    Jul 2009
    Dallas, TX Suburbs
    8
    I have considered adding a SWG, however, based upon the previous condition of the pool, did not think the cost was warranted. I priced converting switching to a Saltwater pool as was quoted slightly under $2K. Based upon the BBB method, this was a no brainer. Properly maintain my pool and avoid all of the craziness I see others have who do not maintain their pools. Just a thought.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I could only find stabilized tabs on their website - I'm sure I just missed it. But if they have unstabilized chlorine tablets, it's guaranteed to be cal-hypo, and A) must definitely NOT be used in a tri-chlor feeder and B) will raise the calcium up and up, just like stabilized tabs raise CYA.
    While we don't recommend it, you can manage a pool using trichlor tabs in a feeder if you manage the CYA level by monitoring it and replacing water periodically to keep it low. Splashout and backwashing help too. It's all about knowing what the sanitizer adds and proactively mitigating the affects of it.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    that's ridiculous. a hayward swg is $700 or less for your size pool. the problem with tabs is that they will constantly raise your cya level. if you don't mind draining your pool every so often, use them. judging from your first post though, that would be way too much work and time. the first thing you need to do (after reading pool-school/ pool chemistry section) is get your chlorine up (actually you need to be shocking). see pool school for instructions on that also. if you don't want to use the bbb method, that's fine, go to a pool store, tell them the deal and they will get you set up. it will be a lot more expensive and it may or may not work, but chances are you'll be able to spend less time on it.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You can use trichlor pucks. (don't use the HTH brand.)
    Just understand what they do to your water. They are acidic, so they lower PH/TA. They contain CYA, so that level will go up with their use. The only practical way to lower CYA is water replacement.
    So if you want to fire the pool guy, you will need one of the recommended test kits, so that you can monitor the PH/TA/CYA levels.
    http://www.troublefreepool.com/pool-...kit_comparison
    Your PH/TA levels will drop with pucks. Borax and Baking soda in combination can be used to keep these levels in range... or Soda Ash/Washing Soda will raise both at the same time.
    Don't think about Borates right now, focus on clearing your pool.
    What probably happened is the CYA level is now at the point where the amount of FC released by the pucks isn't enough to kill the algae that has taken hold. If the pool guy allowed the FC to drop too low at any point it's fairly easy for algae to get in, and then the pucks can't keep up at all. Mustard Algae is particularly stubborn and resistant to "normal" chlorine levels.
    You'll need to shock the pool with bleach/liquid chlorine, until the algae is dead and the FC is holding overnight, then you'll need to run with a higher "min" level of FC to keep the Mustard Algae from returning. You won't be able to do that with pucks, you'll have to use bleach or liquid chlorine and test daily to keep the FC up.
    http://www.troublefreepool.com/chlor...art-t2346.html
    Maybe you don't need to fire the pool guy, maybe you just need to teach him the methods of TFP.
    So order a test kit, and read Pool School. Start with How to Shock your Pool and How to use the Pool Calculator.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by JRock80
    Not sure if you are confusing the two, but a SWG = Saltwater Pool
    As reebok mentions, you could easily find one for around $700-$1000...If someone is quoting you $1000 to install it, they are trying to rip you off.
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by waste
    Welcome to TFP!!
    Waste, God you are right...I knew that... I should have known better. Thanks for putting that out there.
    Beave
    Jul 2009
    Dallas, TX Suburbs
    8
    Looking at my attached photos, you will see why I am hesitant to convert to SWG. I have Oklahoma Flagscape and rocks surrounding my pool.
    [attachment=1:3it1as0y]June 15-19 005.jpg[/attachment:3it1as0y]
    My PB finally got rid of the algae. I guess he finally decided to shock the pool. After spending all day on this site, I went over to Leslies and ordered the FAS-DPD test kit. I also priced some of their chemicals. Are Leslie's chemicals some of the better brands, or are their other sites/stores I should consider. I saw that someone mentioned to avoid HTH, which I think Wal Mart (hate the store anyway) carries.
    Now that the algae problem has been resolved, I am now considering adding the Borax and Acid. Where can I go to find 11 boxes of this stuff at one time or will I have to go to a few stores and purchase all of their stock?
    Beave...would it be worth spending the $250 for the unstabilized pucks instead of buying zillions of gallons of bleach. Would this cause a chemical explosion if I replaced the Tri-Chlor tabs?
    Thank you for all of your assistance thus far. I love the feedback. Keep it coming.
    [attachment=0:3it1as0y]June 15-19 006.jpg[/attachment:3it1as0y]
    11,969
    The Cal-Hypo tabs, while they don't increase the CYA level, they increase the CH level. So eventually water replacement is still required either way, plus I don't think there is an inline unit designed for use with cal-hypo tabs, but I could be wrong. I think they are usually just used in a floater. (Yes, putting cal-hypo pucks in the current feeder could result in explosion.)
    Be sure your FC is holding overnight - even if it looks like he defeated the algae issue, the FAS-DPD test will confirm that.
    http://www.troublefreepool.com/pool-...rnight_fc_test
    Instructions for Borates:
    http://www.troublefreepool.com/so-yo...how-t4921.html
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Cal-hypo would most likely promote calcium build-up in the future on your beautiful pool. I'm not sure a 3000ppm saltwater pool would be an issue at all...but perhaps some of the more experienced will chime in soon
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    are you using that nature2 catridge?
    also, if you haven't paid for it yet, I would order the kit from www.tftestkits.net it's a much better value (lot more reagent) and will probably come quicker. while I was waiting 2 or 3 weeks for my leslie's kit to arrive, I ordered one from www.tftestkits.net and got it in 2 days. I returned the kit to leslie's when it finally showed up. and it only came then cause I called and complained and they said "oh the order is stuck I'll try to unstick it"
    11,969
    What N2 cartridge?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    the one in the picture.
    11,969
    Which? I see an inline chlorinator and a blue thingy, but I don't know what that blue thingy is. Doesn't look like an N2 that I've seen...
    Jul 2009
    Dallas, TX Suburbs
    8
    No, the N2 cartridge has expired and I will not be replacing. That is the reason I was inquiring about the borax. I have read the Pool School and look forward to learning and sharing what I have learned thus far with others. Thank you all for the support.
  20. Back To Top    #20
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    fpm, you are so out of the loop with alternative sanitizers. *sigh* how do you expect to keep your pool in good shape anyway?
    http://www.nature2.com/poolproducts/abo ... xpress.asp
    http://www.nature2.com/poolproducts/ing ... xpress.asp
