Thread: SCHEDULE 40 PVC
    SCHEDULE 40 PVC
    im getting ready to hard plumb my ag pool and wanted to know if the pipes running underground from filter/pump have to be level or can they be at a slight slope?
    thanks,
    mike
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    22,553
    Re: SCHEDULE 40 PVC
    On the pressure or suction side of the pump it doesn't matter. The only thing that really matters is that you don't loop the skimmer piping above the water level before it gets to the pump. And really it's not that big of an issue it just makes the pump hard to prime sometimes.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Re: SCHEDULE 40 PVC
    I just hard plumbed my pool and I had a leak in the middle of the pipe run. Kind of made me angry that a new piece of pvc pipe had a small crack in it. I ended up cutting the cracked part out and splicing it back together,
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
