Thread: heard on a local Home improvment radio show this weekend
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    Called asked about SWG, and was told they are NOT recommended.
    Reason, a friend of his had one installed, and it caused his patio furniture to corrode. And it was not cheap furniture.
    interesting that.
    30,000 Gallons, Hayward C5030 cartridge filter, IG, Plaster, SWG
    Mar 2009
    Glendora, California
    169
    Re: heard on a local Home improvment radio show this weekend
    Sounds like cheap furniture to me.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Mar 2007
    Coastalish 'down easter'
    4,160
    What they did wrong was to not rinse the furniture after a swimmer had used it
    Here's the scenario - person gets out of the pool in a bathing suit soaked in ~3000 ppm saline water and sits on a chair. The suit drips, wetting chair. The 3000 ppm water isn't going to attack the metal quickly however, as the water evaporates, the salt doesn't and soon gets to be 2X + as salty and attacks the furniture. The solution is to either have swimmers rinse off before using the furniture or rinsing the furniture after everyone's done swimming/ using it. It also happens to diving board bolts and slide ladders. If you have a SWCG, keep a hose handy and use it after people swim
    Luv& Luk
    -Ted
    i agree
    18' 52" deep laguna agp with pentair 1 1/2 hp pump and 22" filter, intex swg
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    124
    Waste is right,
    I could see myself forgetting to rinse things down. As stated, the salt doesn't start "destroying" the metal instantly. After everyone is done swimming, taking 2 minutes to rinse down the furniture etc would be more than enough to keep things in good shape.
    33'x15' x 52" Aqualeader
    Gallons ? - (I use appx 13,500 to calculate "stuff")
    33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
    Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
    Intex S.W.G.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    404
    Too funny. Wonder if the same people would complain about chlorine fading the cushions after sitting on the fabric-type outdoor furniture.
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
