Thread: Pentair Universal weir - how to install?
    I inherited a very old pool when we bought our home. It came without a weir. Found this universal one with spring loaded hinge. I thought the flap would go down when the pump is off to trap the debris (thought this was the purpose of the weir). It does not go down. There is some styrofoam on the weir and I have that facing inward toward the skimmer. Am I supposed to remove the foam. Is the weir supposed to close? Do I have my water level too high? What am I missing here? Thanks!
    24,000 gallon chlorine plaster in ground
    Triton II Sand Filter
    Pentair Pool Sweep/Cleaner
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pentair Universal weir - how to install?
    Welcome to TFP!!
    Sounds like you've got it in correctly
    Keep the Styrofoam on! The weir should float up to trap the debris in the skimmer when the pump is off and be sucked closer to horizontal with the pump running to increase the surface action.
    Luv& Luk
    -Ted
    Do I have it in upside down? If I put the hinge on the bottom then it would probably close when the pump is off.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It hinges at the bottom.
    Duh! I think that is my problem. Funny that the pool supply stores don't even know how to install this item!
