Results 1 to 7 of 7
Thread: Hot Tub ?
    Hot Tub ?
    Here's a ? for you. Where do the new posts go if you forget to put a subject in?
    So, I'll start again!
    Have a portable hot tub that shares my pool pump, sand filter and heater and that was winterized. It has a couple feet of pink water in it. Is this antifreeze? Do I run this to waste and it won't hurt the the pump? Also if there is antifreeze in the lines of the pool and ht, I just run it through? The stuff in the pool returns will go into the pool and won't be a problem?
    You'll hear from me a lot! Bought a house in Nov with 32x16 vinyl inground w/ standalone hot tub and no directions except to go to the "pool forum". Trying to post only the stuff I didn't see addressed on pool forum. Glad this site started up!
    Thanks
    Kay
    26,000 Gallons in ground with spa
    SWG
    Jandy equipment
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: Hot Tub ?
    Hi Kay. Being from Houston, I don't know much about winterization but I wanted to encourage you to please post your questions here, even if you also look for answers elsewhere. You may get the same answer, but that will help not only add good content to the site, but also preserve the information since no one knows what the eventual fate of PF will be.
    SeanB
    PS. I'm sure someone else will be along shortly who can answer your question.
    Quote Originally Posted by WshnIwslofn
    Thanks
    Kay
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Thanks SeanB.
    This will be the only site I post to, since you can't register at the pool forum. And the Mod's posting there (who hopefully all join this one) gave such good advice, why would you want to go anywhere else. Really, really glad you started this one!
    Kay
    SWG
    Jandy equipment
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It's antifreeze. I always start my pump on backwash and it goes out the waste line. Some will get in the pool, but I don't know that it can hurt anything.
    Thanks, for the replies.
    Kay
    SWG
    Jandy equipment
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Quote Originally Posted by JohnT
    John,
    Living down south, obviously don't have the worries of long term freezing temps. However, on an environmental side.... if caught, we would be looking at some hefty fines for dumping Antifreeze down the drains. Are there other modes to follow when winterizing??? Just curious.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    SW Indiana
    9,199
    Quote Originally Posted by divnkd101
    John,
    Propylene Glycol is used in the drinking water and drainage systems of RVs and summer cabins, as well as being sprayed on aircraft for deicing. It is also used in automotive engines as an environmentally friendly alternative to ethylene glycol. It is also added to food, particularly fat-free ice cream. The FDA classifies it as "generally accepted as safe" for food use. I think maybe I've heard it is dangerous to cats.
