Thread: Best pool cleaner for LARGE debris
    Jun 2008
    Southern Ontario, Canada
    38
    I have a pool in an area with several large trees. On a windy day I will often get leaves, maple keys, and small twigs in my pool. We have a Kreepy Crawly but it will often stop because of the larger debris. What type of cleaner is best to clean my pool including the large debris
    20 x 40 in-ground concrete
    1 & 1/2 HP hayward pump
    Hayward sand filter
    Aquarite SWG
    Sungrabber Solar Panels
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Best pool cleaner for LARGE debris
    Hi,
    you might want to try a poolskim. If you keep your pump running a lot this may clear up the tree mess before it sinks. I am considering one myself. We have an oak tree that drops a lot of leaves and acorns and some flowering behemoth that drops tiny little tissue paper thin blooms by the thousands. I have Zodiac inline leaf canister but that is only good for keeping large debris out of the pump basket while I vacuum.
    Love TFP? Become a
    TFP Supporter!
    Jun 2008
    38
    A pool skim helps (I have actually modified my leaf cleaner that you use in the spring opening) but I want something that will do this even after they fall in. I do not run my pool filter 24/7 and I cannot be around all the time to be sure it stays clear. Short of getting myself a pool boy.....or better yet, a pool girl trying to make her way through college, I want to get something that won't stop on larger debris.
    Hayward sand filter
    Aquarite SWG
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    The best pool cleaner for large debris is a teenager. Second best is anyone else willing to do the work while you sip a refreshing beverage poolside.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    I am assuming you have a suction side setup.
    The Polaris pressure side seems to do a better job on debris with the booster pump.
    What I have is a POOLVERGNUEGEN ThePoolCleaner (4 wheel) suction and it actually does pretty good on larger things. Large twigs will stop the turbine (get jammed in there), and a batch of leaves will plug the hole, but normally acorns, small twigs, even large leathery oak leaves (one at a time) won't stop it up.
    It is way better on debris than my Hayward ultra was, but not near as good at covering the pool as the Ultra was. It seems to cover the whole pool (only about half way up the walls) but takes 8 hours to do what the Ultra did in 3. But I find I have less "declogging" of the cleaner to do also.
    30,000 Gallons, Hayward C5030 cartridge filter, IG, Plaster, SWG
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    other than a cleaner...I have the same problem, with lots of leaves...we keep a solar cover on the pool when we are not around and catches the leaves before they hit the water...I know it's a pain, but it sure beats cleaning with a leaf rake or overloading our robot.
