Thread: Testing Methods
    Testing Methods
    Thread split to form new Topic by Moderator.
    You keep talking about a good test kit. I have trouble reading the drop type pool kits. So I found a digital meter. Do you know anything about Aqua Chek Trutest Digital Reader?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Testing Methods
    Digital readers have their own issues, from what I understand.
    This thread:
    http://www.troublefreepool.com/epool-t11615.html
    is about Epool, but the Trutest is mentioned briefly.
    When you say you have trouble reading the drop kits, can I assume you mean the OTO and PH tests?
    The FAS-DPD test, included in the recommended kits, is a drop-count test, where you are counting drops until there is a color change from pink to clear, so you aren't "comparing" colors on a view tube. Same with TA, you are counting drops till the solution turns from green to red/pink.
    The CYA test is different, slightly more complex, but still more accurate that strips/digital readers.
    Re: Testing Methods
    I guess mostly the ones from Wal mart or such. If I buy the K-2006 will I be able to better adjust my pool?
    I also have trouble understanding all the codes that everyone uses. So simple minded I am.
    Re: Testing Methods
    I knew several people who had digital meters for their fish tanks and they reported that you had to keep adjusting the calibration, constantly. That is, you had to mix a test solution, then use that to recalibrate the device. Lot of work, IMO.
    11,969
    Re: Testing Methods
    Quote Originally Posted by idahospudnut
    Which codes?
    http://www.troublefreepool.com/pool-..._abbreviations
    Unless you're in Canada, the TF-100 is a better deal for the money, since you get more reagents with the kit, and it uses the same Taylor reagents as the K-2006. TF-100 is not available in Canada.
    http://www.troublefreepool.com/pool-...kit_comparison
    Will you be able to better adjust your pool? You bet.
