Taking the plunge.
I have decided to install an AG Pool. Its 21’ X 43’ 54†Pool.
When I get time, I’ll put the pool specs in my signature.
This is what I’ve done so far.
Day 1
Move all the bushes and relocate them to some other part of the yard.
Day 2
Start the general excavation. I wanted to get the ground level and find where the soft spots were so that I could tell how far down I would have to go to get to firm ground
Day 3
Get to approximate grade. All the dirt that I took out was used to extend the back yard further into the woods. Two birds, one stone.
I put a row of boards down each side of the site setting them level with the laser transit.
What I plan to do is pull a mason string from one side to the other. Start at one end of the site and do a final dig using flat shovels. Then move the string 1 foot at a time shoveling the ground to final grade as I go. This won’t be until the weekend after next. I have to go to Alabama for a wedding so the pool is going to have to wait.
After that I plan to put a layer of modified crush and run down and plat pack it. Once that is done. I will be digging footers for each support post setting them with the laser transit. I noticed in pool instructions that people install a masonry block under the support post to keep it from settling but I would rather have the post sitting on a good pier foundation so that there will be no movement.
Does anyone know if there is any deflection in the post when the pool is filled? I have a pool that uses the buttress free system. If so, I might set them at 2 deg so that the wall comes back into plumb when the pool is filled.
The bottom is going to be sand. I don’t plan on using foam.
Another interesting thing is that we have a lot of moles in our yard.
It would take an all out war to get rid of them so I guess were roommates for life.
I have some metal screen ( doors to HP server cabinets cut in half) that I’ll bury around the pool. It’s about a 16†deep so the moles can’t dig under it. Should help keep roots from growing under the pool.
More pics to come as I continue with the install.
Day 1
Day 2
Day 3
