Thread: Ph Rising after putting weights in step ladder
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    So this is the only thing I can tie directly to my Ph rising in the last 2 weeks. My numbers have been at or near perfect for over a month
    PH 7.4
    TC 6
    CC 0
    CYA 50
    TA 110
    I put some old school metal barbell weights in under my steps to help hold them down about 2 weeks ago. In the last 2 weeks I've had to dump 32 oz each time of muriatic acid in twice to bring PH down from 7.8. It has rained a little bit here in OK the last week or so, but surely not enough to raise PH that much. I checked my numbers again today and they are all back in range. Should I yank those weights out from under the steps or is that just a coincidence??
    IrishAl
    22,100gallon AG
    2.5HP pump
    Alan
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Ph Rising after putting weights in step ladder
    you put iron weights in the water?
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    AAARRRRRGGGHHHH!!!!
    Talk about feeling like an absolute idiot!!! I read your reply and jumped up and yell "oh s$&t" and it dawned on me. Sure enough I yanked those things outa there and they were rusting pretty good. Is there anything I need to do to the water after getting them outa there?? Should I dump a metal sequestarant in there?
    I now have 2 x 1 gallon empty bleach jugs with a little bleach in them filled with play sand holding the ladders down.
    I've come so far with my pool, only to go and do something stupid like this. Hopefully I haven't harmed anything.
    Cheers,
    IrishAl.
    22100 gallon AG
    2.5 pump
    no more cast iron weights holding down my steps
    Alan
    30ft AGP
    2hp pump
    22,553
    If you were careful removing them you may not have a problem. You'll certainly want to test of have your water tested for iron. you may be surprised at just how little you have. I wouldn't panic and add stuff till you know for sure.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Quote Originally Posted by irishal
    . . . jumped up and yell "oh s$&t"
    Oh good! I see others here speak my language
    Tizme, are you reading this?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
