Results 1 to 8 of 8
Thread: Testing chemicals went into pool?
    Hello.
    I know this might sound a bit embarrassing, but I was testing my pool today and the testing chemicals went into the pool. :/
    I tried searching what to do on Google, but nothing showed up.
    Help please?!
    16x34 kidney shape 19,000 gal vinyl IG
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Testing chemicals went into pool?
    What kind of chemicals are we talking about ? I would think that depending on the amount and type you should be ok because the dilution ratio.
    Someone who knows more will chime in shortly.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    30,431
    "When in danger or in doubt, run in circles, scream and shout"
    Seriously, no harm done unless you spilled some very unlikely amount like in the gallon range.
    Like Tiz said, the diltuion is so great, it renders almost anything pretty harmless
    The little testing drops when in. The one that tests the chlorine.
    Some drops went in..
    Are you sure? Because it says not to put in the testing stuff into the pool. o-o
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    yeah you shouldn't. but this is life where accidents happen.
    since you're here, have you read pool-school/ ? I bet there's a lot of good info you'll learn and will probably help you tremendously in caring for your pool, like it did most of us.
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    This reminds me of something I've been meaning to ask....I'm on a septic tank at home. After I run my tests, I run tap water in the sink, dump the beaker, rinse, dump, go the the next beaker, repeat. How nasty are these reagants? Any issue with it going in a SS sink, then PVC plumbing, then into septic? I've yet to see any issues on the sink itself, but I wonder just a bit each time I flush this stuff. I keep remembering what generated this thread which is the warning on my pH test not to put the chemicals back in the pool.
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
    Some of the test chemicals could be dangerous in larger quantities. As long as you have the water running in the sink when you dump them out you will be fine. The OTO test is a mild carcinogen, some of the others are strong acids or bases, some are strong dyes that can easily stain things (but not SS or PVC). All of them will be easily neutralized and broken down in the septic system.
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    Thanks.
