Thread: High CYA level - 120 - Drain half of the pool?
    Jul 2009
    El Paso, TX
    4
    My pool has a CYA level of 120. I was using Dichlor and Trichlor for years but recently switched to bleach. Should I drain half of the pool and then refill it?
    Also, the hardness of the pool is 310. Will I need to add calcium after I refill it? If so, should I just use calcium hypochlorite shock as my chlorine source until the hardness returns to normal?
    1) 20000 gal
    2) DE filter
    3) In Ground
    4) Plaster
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: High CYA level - 120 - Drain half of the pool?
    If the CYA result is from a test strip, I'd have it confirmed with a drop based test, even if it's the 6-way from wal-mart, which is more accurate than test strips.
    I wouldn't drain unless I had an accurate CYA reading from a drop-based kit.
    If you do drain, yes, you can use cal-hypo to chlorinate and raise the calcium level into range.
