Thread: SWG as a line item upgrade
    In a new build, what is the cost, ballpark, to "upgrade" to saltwater? Is there anything besides the actual SWG and the control that are different?
    Houston, TX
    16,500 gallon, 31x14 with raised spa, Pentair Quad DE filter, IG, pebblesheen, 2 hp sta-rite max e pro
    rainbow chlorinator, pcc2000 cleaning and circulation system with 1 hp sta-rite pump
    22,551
    Re: SWG as a line item upgrade
    I'd figure $1000 to $1500 You can get cheaper and some more expensive. It all depends on what you want. The only thing that changes is the cell is added to a run of the piping. Not really a change just a small addition.
    Vero Beach, FL
    462
    $1000 sounds about right. In addition to the cell being added in-line with the return pipe, you also will have the control panel hooked up to electrical and mounted on a wall.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
