I found that the Aquacheck 7 strips that this house had when I moved in were pretty close to what I later measured with the TFP kit. It was just that the ranges on the strips were not very useful and the judgements assigned to the values were wildly inaccurate.
Let's start with CYA, which has possible values of 0 "Low", 30-50 "Ideal", 100 "OK", 150 "High", 300 "High". So, I tested something between 100 and 150 which seems to be a bit high, not a problem apparently though. I'll guess it is 120, maybe 135, I dunno.
On to FC, which has possible values of 0 "Very Low", 0.5 "Low", 1 "Pool OK", 3 "Pool OK and Spa OK", 5 "Spa OK", 10 "High", 20 "Very High". So, my FC on the strips is between 1 and 3. Based on the strips, my pool is OK.
On to TC, which has possible values of 0, 0.5, 1 "OK", 3 "Ideal", 5 "OK", and 10. My TC is 5, which is OK, it says. (No mention on the bottle of the high value of CC's in my pool at this point, so I just didn't realilze that part.)
So, I added some more pucks to the in-line chlorinator and keep the FC at 2.0 and wondered why I am seeing that flush of green in the spa each day and having to brush the pool so often.
Now, based on the TFP kit, not the same day, I actually had CYA of 120, FC of 2.0, TC of 4.0, CC of 2.0 and my target range of FC was 9 to 15. I learn that I need to reduce the CYA to around 40 in order to get my target to 3 to 7. And, by playing around with the Pool Calculator, I notice that in order to get to a point of being able to use the strips "Ideal Range" of 1 to 5 FC for my pool and spa, I'd have to have a CYA of 10
And yet, they tell me that CYA is Ideal at 30-50 and not High until over 150
But, I do still use the strips from time to time. TC of 3 or 5, or higher or lower is useful to know, at my current CYA of 40. And the CYA of 40 is right in the middle of the 30-50 color spot, so that is an easy check if I don't want to take out the whole kit to test it.
The other tests, pH, TA, are OK but I can't add acid based on the uncertainty of the range given. Total hardness is useless but I did find somewhere that CH is probably 2/3 of total hardness which is about right for my pool. And, the strips are 30 cents per test, which is a bit pricy.
