Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Sand filter trouble
    Sand filter trouble
    Hi Everyone,
    I have a Hayward sand filter and I was having problems with the green algae pumping back in the pool when I vacuum. I changed the sand 250# and checked the lateral lines and all piping. I still have the same problem. The only way I can clean my pool is use flock and vac. to waste. Any ideas?
    Thanks
    Costa Rica
    38'X26'
    1hp Sta-Rite
    300# Aquaworks filter
    30,431
    Re: Sand filter trouble
    Hi, Paul,
    Welcome to the forum.
    If you have green algae, you need chlorine in your pool. No filter will filter green algae from your pool. Your sand filter may have some issues or not but it will never get rid of algae....not will any other type filter.
    There are several good articles in Pool School to get you started. Particularly the ABC's of Pool Water Chemistry will explain the importance of chlorine. Post bakc with lots of questions. You'll find all the help you need to get your pool sparkling.
    Thanks Dave. When the algae is dead will the filter not remove it or is that why it is green its not dead? I am going to pool school now.
    Thanks Again
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    30,431
    Paul, when algae is alive in your pool, it is a living, reproducing organism. It simply continues to multiple in your pool, regardless of how much you filter.
    When you kill the algae dead (with chlorine).....all of it....your pool will not look green but usually grey. Now, all that's left is the "carcasses", these are filtered out by your filter (and I'm sure decompose quickly, too).
    Adequate chlorine levels is the key to never let algae get started but once it does, the high doses of chlorine (shocking) is what needs to be done to cure it.
    Thanks Dave. By the way we lived in Whitsett outside of Greensboro for 35 years. We now live in Costa Rica.
    Thanks for your help.
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Costa Rica... How exotic!
    30,431
    Shoot, I was about to post the same thing about Whitsett!!
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    How big is your pump.
    I had this problem as well, when installed a smaller pump i had a TFP pool
    happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Live "green" algae usually makes it right back to the pool if you try to vac it up while it's alive, dead algae (grey powery stuff) will get caught but will clog the filter quickly, vac live algae on waste and even large amounts of dead I would vac on waste as well.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Thanks Kevin.
    The filter is 1hp. Will get the algea killed and get to work cleaning.
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by PaulJohnston
    Thanks Kevin.
    Paul
    well technically your pump&motor is 1HP (not your filter ), with 250lbs sand filter I don't think you are over sized as someone mentioned before happened to them.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    30,431
    Paul,
    Do not vacuum to waste to get the algae out of your pool. it will not work.
    1. Kill the lagae with constant high levels of clorox.
    2. When you've got stuff on the bottom of the pool, vac to waste or into your filter depending on if you can stand the water loss or not.
    Thanks Dave,
    I put 5 lbs of chlorine in last night and it did nothing. PH 7.6. 25,000 gallons. Is it possible to get bad chlorine. I ask because here in Costa Rica there is no regulation or enforcement of consumer products. You have to be careful about everything. Let the buyer beware was never truer. Can I test the stuff. It says 90% but may be 30% who knows.
    Thanks
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    11,969
    So it's powder? What's the active ingredient?
    Can you get Clorox bleach there? That would be best.
    Yes I can get Clorox here. How much should I add? 25,000 gallons water.
    Paul
    Costa Rica
    38'X26'
    1hp Sta-Rite
    Apr 2008
    Thailand
    152
    hello Paul
    If you have been using trichlor, [Trichloroisocyanuric acid] and you used it for a long time. Then you probably have too much CYA in the pool. This will make it next to impossible to clear up your pool.
    The best thing you could do is get a test kit which tests cya and ch cl ph. etc and tell us the results.
    I got a TF test kit, smartest thing i did, because then you know what your pool is doing.
    And read pool school twice
    Happy swims
    Frank
    http://www.tftestkits.net/
    11,969
    Paul
    Without knowing your CYA level, we can only guess. 6 small jugs of Clorox will raise your FC up to a shock level of 10, which is as high as I would suggest until you confirm your CYA level. If your CYA level is higher, so is the shock level - refer to the CYA chart.
    Apr 2008
    Thailand
    152
    Hello again
    Paul you might find these links usefull.
    Frank
    what-we-need-to-know-to-answer-your-questions-t10341.html?hilit=to much cyanuric
    cya-help-t14331.html?hilit=to much cyanuric
    Thanks Frank.
    The chlorine I get here is suppose to be TRICHLOR 90%.
    Costa Rica
    38'X26'
    1hp Sta-Rite
  20. Back To Top    #20
    Apr 2008
    Thailand
    152
    Paul
    How long have you been using trichlor exp 5lbs will raise cya by 13. If you have been using it for awhile your cya will be too high.
    Basically without knowing your test numbers we can't really help.
    IMHO i reckon you have CYA problem and your going to have lower it.
    http://www.poolcalculator.com/
    Cheers Frank
