Thread: jandy 1 speed to 2 speed
    i have a 1 year old, 20k gal inground gunite pool with raised spa. have 1.5 jandy stealth main pump and a 1 hp booster for the polaris 280.
    i have manual valves and manual twin timer for the pump and cleaner pump.
    i want to switch to a 2 speed pump to save on the electricity. question, is there a 2 speed pump motor i can put on my pump that has a toggle switch i can manually use low speed for general circulation and toggle up to the higher speed for the spa?
    21 x 41 Oval AGP (24,000 Gallons)
    Sand Filter
    TF-100 Test Kit
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: jandy 1 speed to 2 speed
    Many pumps come with the switch installed, but motors alone generally do not. You'd have to install your own toggle or rocker switch either on the wall or at the motor.
