Results 1 to 16 of 16
Thread: Houston, We have a problem!!!!
    Loogootee, IN
    122
    I decided to do some back washing today, what I thought was nasty dirty water, turned out to be, FILTER SAND! I don't have any sand in my pool from starting and stopping the pump for the last 6days, but about 5-10seconds of back washing produced this!!!!
    So what did I do wrong?
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Houston, We have a problem!!!!
    I could be wrong bt it looks to me like a lateral has either broke or come off inside your filter. I think its an easy fix but someone who knows more will chime in soon.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Loogootee, IN
    122
    Man, I was afraid of that!!!!
    No offense, but others, please prove Tiz wrong, PLEASE... lol
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I know how you feel Pachinko. We ha d one come off right after we had our poolinstalled. Thank goodness the pool installer came back and fixed it. I did watch him fix it and he had to remove all of the sand because of course it was a lateral at the bottom and i think ours popped off it wasnt broken so he just put it back on. He said the hardest part was getting the sand out because he had hands like The Hulk !!! LOL !!
    Les
    Helpful Links:
    Mar 2007
    Coastalish 'down easter'
    4,160
    If this happened on backwash, the laterals don't really come into play As long as sand isn't going into the pool on filter, no need to suspect a lateral problem.
    You may have too much sand in the filter. The other thing I've seen is 'gunked up' sand that gets blown out when backwashing (i.e. the top layer of 'gummed up' sand gets flushed out when you backwash)
    Luv& Luk
    -Ted
    Loogootee, IN
    122
    there is a strainer bowl type thingy that went inside the filter, when I was done putting the 200lbs it said to put in, you couldn't hardly see the strainer because of the sand.
    Should I just back wash and the sand will stop once it is at the proper level?
    30,419
    When did you put the sand in? Just prior to backwashing?
    Loogootee, IN
    122
    about 6 days ago. I can filter and rinse with no problem.
    30,419
    If that was the first time you backwashed since adding the sand, I believe Ted has solved your problem. Generally, the filter should be about 2/3 full of sand altho each filter may vary a little....check the Manufacturer's website for confirmation.
    Loogootee, IN
    122
    So do I need to open up the filter and take some out? Or can I get to the proper level by back washing until sand stops coming out?
    When I was finished with the 200lbs, the sand level was at the bottom of the neck of the filter.
    30,419
    W-a-a-ay too much sand. (Excellent diagnosis, Ted, I wouldn't have caught that)
    Try to find info online for correct level for your model filter. If that fails, empty sand down to 2/3 of the body of the filter until you can find out what's optimum for your particular filter.
    I would suggest removing it carefully by hand. Backwasing to get it out just doesn't seem like a great idea. Others with more experience may correct me.
    Loogootee, IN
    122
    it is a Jacuzzi Laser Filter 190L on the filter it has the specs and under "media" it says 200lbs
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Pachinko I was just looking at the manual online and it said to fill the sand to 1" - 2" below the basket and you should be using 20# silica sand.
    Les
    Helpful Links:
    Loogootee, IN
    122
    Whoa!!! Yep, I have way too much sand in my filter!!!! Guess I better get off of here, and start scooping..
    Thanks Tiz!!!
    Loogootee, IN
    122
    I opened up the filter and the sand is now just a hair under the basket. so I closed it up and did a back wash, i could feel the grittiness of the sand on my hand for about 2-3seconds then nothing. looked at the sight glass and there was just a little bit left and was slowly diminishing.
    back washed for a little over a minute, then rinsed about 10-15secs. then switched it to filter. the return isn't as powerful as what it was. and when I first started the pump system for the very first time. I had a reading of 14psi.
    Now that I have back washed etc, today it is running right at 10psi.
    Anything wrong with that???
    Mar 2007
    4,160
    Now that you have the correct amount of sand in the unit, you should be good to go
    If this thing gives you more problems, just let us know and we'll help
    Luv& Luk
    -Ted
