Results 1 to 13 of 13
Thread: It Lives
    Jul 2009
    South Texas
    32
    It Lives
    Still some sediments around edges that needs to be cleared and I'm still keeping the chlorine high. Brittle nasty hoses replaced skimmer and other fixtures cleaned and brushed. Filter and skimmer up and working again.
    Saturday
    Friday -
    Thursday
    Wednesday
    Monday
    Sorry but I didn't take pictures of before we started.
    Beginer trying to save parent's neglected pool
    Pool Specs: 24ft by 52in round above ground vinal and metal fram 13,500 gallon
    New sand filtration system
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: It Lives
    Looks like you've got it under control
    Thanks for the pics
    Luv& Luk
    -Ted
    22,553
    Re: It Lives
    This is the one that says it all!!!!
    I bet the parents will be absolutely amazed.
    Great job.
    Arizona
    924
    Re: It Lives
    Wow! You have done a wonderful job, TabiCat.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Casey's Avatar
    SW PA
    10,461
    Re: It Lives
    WOOO HOOOOO! Have they seen it yet?
    My smilie really wants to do back flips!
    Jul 2009
    South Texas
    32
    Re: It Lives
    Quote Originally Posted by Casey
    Jul 2009
    South Texas
    32
    Re: It Lives
    Ok Thanks to you all the pool is clear and has stayed clear for days. no more GUNK and water is SO pretty!!
    Mom is 100% sold on the BBB.
    She will be ordering the new test kit on payday . I'm actually a little surprised that she went for it since she was beginning to see the pool as a money pit but I bookmarked Pool School for her and I think she has been doing some reading.
    We know from resent pool store testing that the pH is creeping back up. To 7.8 and the TA is at 154. This both need to come down.
    I treat both with the acid correct? I went to the calculator and have the estimated amount of acid so I'm going to do the first treatment tonight. Do I then need to do the aeration method to bring up PH so I can lower again?
    What do I do if I get the pH too low? Aerate right?
    Arizona
    924
    Re: It Lives
    Try not to get it too low. Maybe use 1/2 of the dose while pump is running and 30 to 60 minutes later recheck and recalc for the rest of the dose so you don't bring it down too low. It isn't always that easy to raise the ph by aeration quick enough. So try to get it between 7.0 and 7.2 and then aerate to bring it back to 7.5 and then repeat the process, retesting your ph and TA every time, until you get your TA down to the level you desire.
    Buggs
    Jul 2009
    South Texas
    32
    Re: It Lives
    Thanks Buggs
    Casey's Avatar
    SW PA
    10,461
    Re: It Lives
    I'm so happy mom is sold on BBB and she's going to order a test kit soon!
    Congratulations TabiCat! You've done a wonderful job and keeping it clear since starting!
    Feb 2009
    West Virginia
    216
    Re: It Lives
    Great job, Tabicat!
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    Re: It Lives
    You win the Good Daughter award this year.... Bravo!
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Re: It Lives
    Tabicat...awesome job with the pool...It just goes to show you that any pool no matter how bad it is, can be cleared up with a little POP! Those last two pictures are worth a thousand bucks.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
